Hello.
I'm trying to initiate a GDB session with a Digi CC-WMX53-LX board which has a ConnectCore Wi-i.MX53 module on it.
Connection seems to work but programming does not. Anyone know anything about halting issues? At the same time jlink commander seems able to halt the target.
- SEGGER J-Link GDB Server V6.00e GUI Version
- JLinkARM.dll V6.00e (DLL compiled Aug 4 2016 09:37:38)
- -----GDB Server start settings-----
- GDBInit file: none
- GDB Server Listening port: 2331
- SWO raw output listening port: 2332
- Terminal I/O port: 2333
- Accept remote connection: localhost only
- Generate logfile: off
- Verify download: on
- Init regs on start: off
- Silent mode: off
- Single run mode: off
- Target connection timeout: 5000 ms
- ------J-Link related settings------
- J-Link Host interface: USB
- J-Link script: none
- J-Link settings file: none
- ------Target related settings------
- Target device: iMX535
- Target interface: JTAG
- Target interface speed: auto
- Target endian: little
- Connecting to J-Link...
- J-Link is connected.
- Firmware: J-Link Pro V4 compiled Aug 3 2016 18:51:26
- Hardware: V4.00
- S/N: 174301086
- Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
- Checking target voltage...
- Target voltage: 1.80 V
- Listening on TCP/IP port 2331
- Connecting to target...WARNING: At least one of the connected devices is not JTAG compliant (IEEE Std 1149.1, 7.1.1.d, IR-cells). (NumDevices = 3, NumBitsSet = 2)
- WARNING: At least one of the connected devices is not JTAG compliant (IEEE Std 1149.1, 7.1.1.d, IR-cells). (NumDevices = 3, NumBitsSet = 2)
- J-Link found 3 JTAG devices, Total IRLen = 13
- JTAG ID: 0x1BA00477 (Cortex-A8)
- Connected to target
- Waiting for GDB connection...Connected to 127.0.0.1
- Reading all registers
- Read 4 bytes @ address 0x77817148 (Data = 0xE3110020)
- Read 4 bytes @ address 0x77851209 (Data = 0x4D574343)
- Read 4 bytes @ address 0x4D57433A (Data = 0x00000000)
- WARNING: CPU not halted after Reset, halting using Halt request
- WARNING: CPU could not be halted
- ERROR: Bad JTAG communication: Write to IR: Expected 0x1, got 0xF (TAP Command : 10) @ Off 0x5.
- Resetting target
- Downloading 4096 bytes @ address 0x70000000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70001000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70002000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70003000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70004000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70005000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70006000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70007000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70008000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x70009000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x7000A000WARNING: CPU could not be halted
- - Verify failed
- Downloading 4096 bytes @ address 0x7000B000WARNING: CPU could not be halted
- SEGGER J-Link Commander V6.00e (Compiled Aug 4 2016 09:38:11)
- DLL version V6.00e, compiled Aug 4 2016 09:37:38
- Connecting to J-Link via USB...O.K.
- Hardware version: V4.00
- S/N: 174301086
- License(s): RDI, FlashBP, FlashDL, JFlash, GDB
- IP-Addr: DHCP (no addr. received yet)
- VTref = 1.804V
- Type "connect" to establish a target connection, '?' for help
- J-Link>device imx535
- J-Link>connect
- Please specify target interface:
- J) JTAG (Default)
- S) SWD
- TIF>J
- Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
- JTAGConf>
- Specify target interface speed [kHz]. <Default>: 4000 kHz
- Speed>1000
- Device "IMX535" selected.
- TotalIRLen = 13, IRPrint = 0x0101
- 149.1, 7.1.1.d, IR-cells). (NumDevices = 3, NumBitsSet = 2)
- ARM AP[0]: 0x44770001, AHB-AP
- ARM AP[1]: 0x24770002, APB-AP
- ROMTbl 0 [0]: 00001003, CID: B105900D, PID:04-000BB907 ETB
- ROMTbl 0 [1]: 00002003, CID: B105900D, PID:04-104BB921
- ROMTbl 0 [2]: 00003003, CID: B105900D, PID:04-004BB912 TPIU
- ROMTbl 0 [3]: 00004003, CID: B105900D, PID:04-104BB922
- ROMTbl 0 [4]: 00005003, CID: B105900D, PID:04-000BB906 ECT / CTI
- ROMTbl 0 [5]: 00006003, CID: B105900D, PID:04-003BB906 ECT / CTI
- ROMTbl 0 [6]: 00007003, CID: B105900D, PID:04-003BB906 ECT / CTI
- ROMTbl 0 [7]: 00008003, CID: B105900D, PID:04-104BBC08 Cortex-A8
- Found Cortex-A8 r2p5
- 6 code breakpoints, 2 data breakpoints
- Debug architecture ARMv7.0
- Data endian: little
- Main ID register: 0x412FC085
- I-Cache L1: 32 KB, 128 Sets, 64 Bytes/Line, 4-Way
- D-Cache L1: 32 KB, 128 Sets, 64 Bytes/Line, 4-Way
- Unified-Cache L2: 256 KB, 512 Sets, 64 Bytes/Line, 8-Way
- System control register:
- Instruction endian: little
- Level-1 instruction cache enabled
- Level-1 data cache enabled
- MMU enabled
- Branch prediction enabled
- Found 3 JTAG devices, Total IRLen = 13:
- #0 Id: 0x1BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
- #1 Id: 0x00000001
- #2 Id: 0x1190D01D
- Cortex-A8 identified.
- J-Link>h
- PC: (R15) = 77817148, CPSR = 200001D3 (SVC mode, ARM FIQ dis. IRQ dis.)
- Current:
- R0 =00000000, R1 =00000060, R2 =53FBC0B4, R3 =53FBC000
- R4 =77861BE4, R5 =00000000, R6 =77860784, R7 =7785B53C
- R8 =77817150, R9 =77817150, R10=7740061C, R11=00000000, R12=00000001
- R13=77851209, R14=53FBC0B4, SPSR=773FFE70
- USR: R8 =7740061C, R9 =00000000, R10=00000001, R11=77851209, R12=53FBC0B4
- R13=7C9B7FE6, R14=5D8D5C97
- FIQ: R8 =A4BD3EEC, R9 =BC268EB7, R10=F925BB74, R11=7C75B317, R12=34F73FDE
- R13=9FBFCFAF, R14=6D7B9865, SPSR=00000000
- IRQ: R13=C04B9076, R14=C40F16B7, SPSR=00000000
- SVC: R13=773FFE70, R14=77826FA0, SPSR=00000000
- ABT: R13=AC1763BE, R14=AFAFCCDF, SPSR=00000000
- UND: R13=BC67FFF6, R14=9C37F67A, SPSR=00000000
- J-Link>loadfile test.hex
- Downloading file [test.hex]...
- O.K.
- J-Link>setpc 0x70000000
- J-Link>s
- 70000000: 18 F0 9F E5 LDR PC, [PC, #+0x18] ; 0x70000020
- J-Link>s
- 700001C0: 70 10 9F E5 LDR R1, [PC, #+0x70] ; 0x70000238
- J-Link>s
- 700001C4: 10 1F 0C EE MCR p15, 0, R1, c12, c0, 0
- J-Link>h
- PC: (R15) = 700001C8, CPSR = 200001D3 (SVC mode, ARM FIQ dis. IRQ dis.)
- Current:
- R0 =00000000, R1 =70000000, R2 =53FBC0B4, R3 =53FBC000
- R8 =700001D0, R9 =700001D0, R10=7740061C, R11=00000000, R12=00000001
- J-Link>
