__ARMVFP__
  • My imported ST Cube project is complaining:
    #ifndef __ARMVFP__
    #error This port can only be used when the project options are configured to enable hardware floating point support.
    #endif
    I've selected hard floating point and the correct architecture in `Code Generation` (see attached). I can hack this and try to define this macro but what is the proper way to get this work. I have another (non-Cube) based project that does not use the ST HAL for this same processor with FreeRTOS integrated and do not have this error but I cannot find the difference between the two.
    Thanks.
    Yes, __ARMVFP__ is a preprocessor define which is set by the IAR compiler.
    These defines are set by Embedded Studio / GCC, based on the project configuration:
    __ARM_ARCH_VFP__
    __ARM_ARCH_VFP3_D32__
    __ARM_ARCH_VFP3_D16__
    __ARM_ARCH_VFP4_D32__
    __ARM_ARCH_VFP4_D16__
    __ARM_ARCH_FPV4_SP_D16__
    __ARM_ARCH_FPV5_SP_D16__
    __ARM_ARCH_FPV5_D16__
    Johannes
