SES 3.10d on Linux, source not displayed correctly
  • SES 3.10d on Linux, source not displayed correctly
    I just downloaded and installed SES 3.10d for Linux:
    Release 3.10d Build 2016092700.29750
    Linux x64
    When I open it, it loads a default project and displays the source as in the attached screenshot.
    This seems like a bug to me.
    Is there any setting where I can influence how the code is displayed?
    Is the behavior known and already fixed somewhere?
    Can I report this somewhere? I only use the EDU version. But I guess the guys at Segger are interested in this.
    Thanks for any hints,
    Torsten
  • Hi Torsten,
    This does not look correct.
    Can you give some more information about your system, so we can try to reproduce it?
    Which Linux distribution do you use?
    Johannes
  • Hi Torsten,
    Could you also create a support report (Help -> Create Support Report...) from your Embedded Studio?
    Johannes
  • Hello Johannes,
    Thanks for your help.
    I'll attach the output of the Help report to this Message.
    My System is basically OpenSuse 42.1 with some media extensions from Pacman:
    tmohr@schleim:/tmp> cat /etc/os-release
    NAME="openSUSE Leap"
    VERSION="42.1"
    VERSION_ID="42.1"
    PRETTY_NAME="openSUSE Leap 42.1 (x86_64)"
    ID=opensuse
    ANSI_COLOR="0;32"
    CPE_NAME="cpe:/o:opensuse:opensuse:42.1"
    BUG_REPORT_URL="https://bugs.opensuse.org"
    HOME_URL="https://opensuse.org/"
    ID_LIKE="suse"
    I guess you may be interested in the version of some of the used libraries?
    I'm not sure what you use as GUI library (qt? wxWidgets? Java?)?
    Torsten
    • Report1.txt
      (12 kB, downloaded 622 times, last: )
  • The issue has been resolved and the fix will be included in the upcoming version of Embedded Studio.
    Johannes
