[SOLVED] STM32L011x4 with wrong Flash-Ram sizes in J-Flash V6.10?
  • [SOLVED] STM32L011x4 with wrong Flash-Ram sizes in J-Flash V6.10?
    my real Chip is a STM32L011F4, but it isn´t in the list.
    So i select a STM32L011E4, should be the same memory map, only in an other package, with more pins.
    In the "Select device" dialog it is said:
    Flash Size: 16KB + 2KB + 32Bytes
    RAM: 8KB
    On the flash tab the sectors a described:
    131 Sectors, 3 Ranges:
    0x08000000 - 0x08003FFF (16KB of flash)
    0x08080000 - 0x080807FF (2KB of EEPROM)
    0x1FF80000 - 0x1FF8001F (32B of option bytes)
    According to ST the chip should have:
    Flash Size: 16KB (Flash) + 512Bytes (EEPROM) + 32Bytes (option bytes)
    RAM: 2KB
    out of the ST data sheet, i get this information:
    0x08080000 - 0x080801FF (512B of Data EEPROM)
    0x1FF80000 - 0x1FF8001F (32B of option bytes, but only 20 of them are really usefull)
    And whe i try to do a chip erase, i get an error when trying to erase the 2KB of EEPROM, probably baceause there are only 512 bytes in the chip.
    Erasing chip ...
    - 131 sectors, 3 ranges, 0x8000000 - 0x8003FFF, 0x8080000 - 0x80807FF, 0x1FF80000 - 0x1FF8001F
    - Start of preparing flash programming
    - ERROR: Failed to prepare for programming.
    Failed to execute RAMCode for RAM check!
    - End of preparing flash programming
    - ERROR: Failed to erase chip
    I can change the RAM to 2KB on the MCU Tab, then the RAM error is gone, but still noch chip erase is possible.
    Erasing chip ...
    - Start of determining dirty areas in flash cache
    - End of determining dirty areas
    - CPU is running at 4189 kHz.
    - Chip erase not supported for flash bank @ 0x08000000. Switched to sector erase
    - Start of erasing sectors
    - Erasing range 0x08000000 - 0x08001FFF (064 Sectors, 8 KB)
    - Erasing range 0x08002000 - 0x08003FFF (064 Sectors, 8 KB)
    - Erasing range 0x08080000 - 0x080807FF (001 Sector, 2 KB)
    - ERROR: PC of target system has unexpected value after erasing sector. (PC = 0xFFFFFFFE)!
    ---------------------------------------------------------------------- Registers -------------------------------------------------------------------------------------
    PC = FFFFFFFE
    Current: R0 = 080801FC, R1 = 00000214, R2 = 00000000, R3 = 00000000
    R4 = 08080000, R5 = 08080200, R6 = 000001C0, R7 = 40022004
    - End of erasing sectors
    - ERROR: Erase failed
    When i deselect the sector 128 (0x08080000-0x080807FF) and do a "erase sectors", it works.
    So can you please have a look into this, and add correct support for the STM32L011F4.
    Thanks.
    Raimund
  • Hi Raimund,
    thanks for your inquiry.
    I plan to check this later today / tomorrow morning.
  • Hi Raimund,
    please find below a link to a preliminary version which should fix this issue:
    EDIT: Link to preliminary version removed, please refer to the official build of the J-Link software & documentation pack.
    Could you please give it a try and provide feedback if it works for you?
