I have a problem with programming ext. Flash memory. I used S25FL128S (QSPI with SPIFI lib) with LPC1853 as flash for screens and audio files. It work's fine - with Keil Flash Programming Algorithm and with JLink commander (directly).
I tried do the same with Winbond W25Q128FVFG flash memory. According to your compatible list, it is supported by J Link to program directly from command line.
But it doesn't work (Error: Error while determining flash info (Bank @ 0x14000000), Unspecified error -1).
It seems to be problem with reading Status Register (W25Q128FVFG has 3 R/W Status Register in contrast to S25FL128S - 2 Status Registers).
But in your website it is listed as full compatibility. Why it doesn't work?
HW Setup:
[img]http://i.imgur.com/38R9Zw0.jpg[/img]
I tied to program it via SPI (without uC, image below) but i get message - "your JLink is to old to program this memory via SPI" (something like that:) ).
[img]http://i.imgur.com/JrlclLM.jpg[/img]
An attempt to write the Flash Programming Algorithm also did not succeed ( I can't program flash via Keil with JLink).
Could you help me? Why it doesnt work?
PS. J-Flash give me :
- Error while determining flash info (Bank 1 @ 0x14000000)
DCWR
HW Setup:
DCWR
The post was edited 6 times, last by DCWR ().
