I have been pulling my hair out (which I can ill-afford) trying to get my j-link Pro to download firmware to my target board.
I am using WICED which is derived from Eclipse.
I developed some working software that sends telemetry to Azure IoT hub using a Broadcom Eval board.
Now I need to move onto the actual hardware which has a SWD interface. Segger recognized the WiFi module so I know that is working.
I installed the Segger J-link plug-in into WICED (eclipse). The configurations window shows J-link features under the debugger and the Startup tabs.
The make target references the WiFi module ( Telemetry-CEL_WB4343WF3SP2 JTAG=jlink download )
The program compiles and links without error.
But when it comes time to download it to the target board I get the now infamous:
"**** OpenOCD failed - ensure to have installed the driver from the drivers directory ..." error message.
The drivers directory only has one entry and it is BCM9WCE1EVAL which is the Eval board that I used successfully. This is a bit suspicious as I don't know how to (or if I need to) include a driver entry for my CEL module.
My .gdbinit file looks like this...
shell start /B ./tools/OpenOCD/Win32/openocd-all-brcm-libftdi.exe -f ./tools/OpenOCD/Jlink.cfg -f ./tools/OpenOCD/stm32f4x.cfg -f ./tools/OpenOCD/stm32f4x_gdb_jtag.cfg -l build/openocd_log.txt
The first entry in the openocd_log.txt looks like this....
Open On-Chip Debugger 0.9.0-00029-gafd5db2-dirty (2015-05-29-18:47)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
jtag_ntrst_delay: 100
Warn : target name is deprecated use: 'cortex_m'
jtag_init
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: Cannot find jlink Interface! Please check connection and permissions.
I've been at this for almost a week and it is frustrating fighting my tools rather than using them to do my job.
I've heard rumors that J-link does not work with openOCD. Is this so? Is there a work-around?
Any thought would be gratefully received.
Bill
jtag_init
Bill
