Sample SystemView project for NRF51 (nrf51422 : no SysTick, no OS)
  • Sample SystemView project for NRF51 (nrf51422 : no SysTick, no OS)
    Hello everyone,
    We are using Segger J-Link, RTT, Ozone for our project that is based NRF51422. The project uses Nordic Bluetooth stack, various peripherals such as LED Matrix, Button, etc.
    Very often we have a lockup situation while using LED driver via i2c and button. We interested in using SystemView for our project to profile and debug the firmware during the development process. However, NRF51422 doesn't have a Systick. We are using Low Frequency RTC (32 KHz) as an application timer. Also we don't have an OS. Our firmware runs with NRF Softdevice and Bootloader.
    Is there any sample SystemView project that is made for NRF51?
    Is it possible for SystemView to records all IRQs automatically?
    Is it possible to measure CPU load?
    Thanks in advance
    You can use the Low Frequency RTC for the SystemView tiemstamps as well.
    Just make sure your configuration is correct and you provide a SEGGER_SYSVIEW_X_GetTimestamp() or alike which generates the timestamp from the RTC.
    IRQs cannot be recorded automatically, if the IRQ handlers do not call a generic function, i.e. Enter/Leave_Interrupt(), yet, all of them need to be instrumented.
    If the application sends accurate information when it idle and when it is executing, you will see the load in SystemView.
    Johannes
