I'm trying to understand how to call dialogs and window from different files based on the segger exemple. I have a STM32F469NI-Disco and I'm using the STemWin_SampleDemo as a starting point, included in STM32F4cube 1.13, with the touch-screen enabled and the demo's applications removed.
I'm using STemWin 5.32.
When I start the MainTask(); in VSCREEN_MultiPage there is no problem. As soon as I click on one of the button I get this :
The STM board is still functionning and reacting to external input through the touch screen and the CAN bus.
In the debugger, I'm able to see that the application VSCREEN_MultiPage read the input of the button and that the corresponding task are opened.
The error I get is reproductible in different StemWin exemple with multiple dialog in seperated files :
I've been going through the STemWin_SampleDemo's code for a while as it is the only working exemple I have with mutiple dialogs and I cannot find why I get the fuzzy screen .
Did I miss the declaration in order to use dialogs ? Is it related to the memory ?
Had someone encountered a similare issue ? I cannot find in this forum a similar case.
Thank you for your support.
Looking forward to hear from you.
Edit. I've rollback to STM32F4cube 1.10 with STemWIN 5.28 and I do not get this problem ?( I do get the problem now in 5.28
I'll try again using STL32F4cube 1.10 with STemWIN 5.32 and see what happens.
Edit.
The post was edited 3 times, last by Schrödinger ().
