I'm confused about the concept of a programmer for microcontrollers. Hoping someone can clarify.
When I use an Arduino, I can use another Arduino to program it via the SPI pins. I understand this to mean that the SPI pins behave as programming pins using a certain programming protocol when certain conditions that put the microcontroller into programming mode are met. So, the programmer is nothing more than hardware that knows how to speak the programming protocol.
When I read about ARM processors, often I read that I need a Segger JLink. Otherwise I cannot program it. Development kits often have a Segger chip on the board. So, this is a programmer for ARM chips. If so, why can't an Arduino, or some other general purpose hardware, also speak the programming protocol for ARM?
Also, what is so special about programmers that it has to be hardware and cannot just be software as long as the microcontroller pins can be hooked up properly and the software can control those pins? If this really is the case, why are Segger products so expensive? What is their secret sauce that seems to give them some sort of monopoly?
If it's important to this discussion, the specific microcontroller I'm thinking about is the nRF51822 with an ARM CortexM0MCU.
