[ABANDONED] Flash programming using JLink on Atmel ATSAM
  • [ABANDONED] Flash programming using JLink on Atmel ATSAM
    I am trying to use JLink to program the "USER_PAGE" of an Atmel chip (ATSAML21J18 ).
    This USER_PAGE is a flash sector (256 bytes) that defines, among others, the size of the bootloader that I need to flash on this chip.
    I can correctly connect and read memory at this sector and write does not give me an error, however the memory is not programmed...
    Firmware: J-Link V9 compiled Mar 29 2016 18:46:37
    Hardware version: V9.30
    S/N: 59XXXX50
    License(s): GDB
    VTref = 2.731V
    Device "ATSAMD20J18" selected.
    Found SWD-DP with ID 0x0BC11477
    Found Cortex-M0 r0p1, Little endian.
    J-Link>mem32 0x00804000 2
    00804000 = B11E86FB FFFFF8BB
    J-Link>w4 0x00804000 0xB11E86FF
    Writing B11E86FF -> 00804000
    I tried writing one byte at a time, 16bits word, 32 bits, nothing works.
    I also even try to write an hex file of the sector and load it on the flash :
    1. :0200000200807C
    2. :10400000FF861EB1BBF8FFFFFFFFFFFFFFFFFFFFB3
    J-Link>loadfile C:\Users\Me\Atmel\USER_PAGE.hex 0
    Connection to device lost. Trying to reconnect to target.
    Downloading file [C:\Users\Me\Atmel\USER_PAGE.hex]...
    WARNING: CPU is running at low speed (5310 kHz).
    J-Link: Flash download: Flash programming performed for 1 range (256 bytes)
    J-Link: Flash download: Total time needed: 0.080s (Prepare: 0.069s, Compare: 0.001s, Erase: 0.003s, Program: 0.001s, Verify: 0.000s, Restore: 0.003s)
    O.K.
    J-Link>mem32 0x804000 2
    Same result, and even worse, if I try to load the file again I have this:
    J-Link: Flash download: Flash download skipped. Flash contents already match
    O.K.
    But when I read the memory again the value is not changed. I am really confused here.
    I know that this memory sector has some reserved bits, could that prevent me to program this sector?
    Is there any way to program only one bit of a byte using jlink?
    Thank you very much for your help.
    the w1/w2/w4 commands can be used to write to RAM, not Flash.
    Using a .hex file is a possible way, but it seems that you have a typo in your .hex file.
    1. :0200000400807A
    2. :10400000B11E86FBFFFFFFF8BB00000003000000AD
    3. :00000001FF
    Please not that you doing this an your own risk. I did not look up want writing this value into the config area of the Atmel chip does.
  • RE: Flash programming using JLink on Atmel ATSAM
    S/N: 59XXXX50
    License(s): GDB
    VTref = 2.731V
    1. :0200000200807C
    O.K.
    O.K.
    Datasheet: atmel.com/Images/Atmel-42385-SAM-L21-Datasheet.pdf
    I've worked a lot with the atsaml21j18, both the a and b revisions, in the past year. Unfortunately, changing the NVM User Row is not as simple as just writing the bits to address 0x00804000.
    For your own reference I suggest reading up on the NVMCTRL section of the datasheet, section 28, page 489. Of particular interest is section 28.6.4, even more specifically sections 28.6.4.3 NVM Write. Note that these are general instructions, and unfortunately the datasheet does not do a great job explaining the steps needed to modify the nvm user row, located in nvm auxillary space. Below I'll outline these steps.
    So the order of operations (I'm using the asf/sam0/drivers/nvm/nvm.c driver as reference)
    1. Read NVM user row 0x00804000 and modify the specific bits you want.
    2. NVM erase AUX Row: NVMCTRL.ADDR[21:0] = 0x00804000 / 4; NVMCTRL.CTRLA[15:0] = 0x05 (EAR) | 0xA500 (CMDEX);
    3. NVM clear page buffer: NVMCTRL.CTRLA[15:0] = 0x44(PBC) | 0xA500 (CMDEX);
    4. Write NVM user row, the full 64 bits, to address 0x00804000
    5. NVM write AUX Row: NVMCTRL.ADDR[21:0] = 0x00804000 / 4; NVMCTRL.CTRLA[15:0] = 0x06 (WAP) | 0xA500 (CMDEX);
    This procedure should modify the user row bits.
    Let me know if you have any trouble, I can try and write this out as a jlink command set, which I need to do for myself here soon anyway
