[SOLVED] Unable to upgrade firmware on JLink Base
  • [SOLVED] Unable to upgrade firmware on JLink Base
    I have just purchased a JLink Base, and have installed the latest Jlink s/w on my PC (Windows 10).
    When I connect the device & run JLink (5.12i), I get a message asking me to upgrade the JLink f/w.
    When I try to do this, it fails.
    It successfully detaches (after 103ms), then waits for it to attach, but this times out (after 45000 ms).
    The errors reported are :
    ERROR: Communications Timeout. Emulator did not re-enumerate
    ERROR: Firmware upgrade failed
    Any suggestions ?( ?
    New f.w is v10 compiled april 28 2016 11:49:37
    Current f/w is v10 compiled Oct 9 2015 20:36:39
    John
  • Hi John,
    after the failed firmware upgrade, once you disconnected and reconnected the J-Link from you PC, which firmware does J-Link Commander(jlink.exe) report?
    Could you try to upgrade the firmware on a different PC?
    I just gave it a try and upgrading a J-Link V10 worked without any issues.
  • Hi John,
    good to hear that you are up and running!
