[Solved] Viewing Peripheral (memory-mapped) Registers
    • [Solved] Viewing Peripheral (memory-mapped) Registers
      I'm using an STM32F415. I am not using SES to build only to to debug an externally generated .elf file.
      There is this from the manual:
      The Registers window shows the set of register groups defined in the memory-map file the application was built with. If there is no memory-map file associated with a project, the Registers window will show only the CPU registers.
      This described what I am seeing but where do I find a memory-map file and how do I associated with my project? I did tell the project which processor I am using so I was surprised that it did not know about the registers.
      Kenny
      The post was edited 1 time, last by Kenny ().
