[SOLVED] Using RTT logging without GDB debugging
  • [SOLVED] Using RTT logging without GDB debugging
    Hi there,
    I'd like to automate the running of some test code on my boards. The aim is to have a makefile target, "make test" which:
    * Compiles my firmware with a -D flag set for test
    * Flashes the code to my board
    * Starts JLinkRTTClient
    * Runs my code, so that I can watch the log output on the terminal
    I notice that JLinkRTTClient looks to connect to localhost:19021 and that there's a server there listening if I also start JLinkGDBServer. I'd like to keep it simple, however, and not start the GDB server if I can avoid it. Same goes for the GDB client. I don't want to have to interact with the GDB client in order to start the test output.
    Is there a way to start *just* the RTT server and RTT client and have the code execute immediately? I've checked the command line options in the PDF doc, but haven't found anything to control this.
    Thanks.
  • As it happens, v5.12f was released just today and now includes the JLinkRTTLogger executable for Mac. So I can now run that instead of JLinkRTTClient, but I still have questions about getting this working.
    1. Does JLinkRTTLogger still require JLinkGDBServer to be running?
    2. What are the command line options? If I pass these in, they seem to be ignored:
    /Applications/SEGGER/JLink/JLinkRTTLogger -device nrf51822 -if swd -speed 1000
    /Applications/SEGGER/JLink/JLinkRTTLogger --help
    3. Can I get the output to go to stdout rather than a file?
    At the moment, all I can get the logger to do is produce an empty log file.
    Thanks.
    JLinkRTTLogger does not require any other J-Link software to be running.
    Currently RTT Logger does not support configuration via command line options.
    The purpose of RTT Logger is to write the output into a file, therefore it is not possible to send it to stdout.
    By default RTT Logger logs the output on RTT Channel 1, it needs to be set to 0 to log the default Terminal output.
    If you require any more advanced RTT logging functionality,
    you could use the J-Link SDK to create your own RTT logging application.
    Johannes
    It seems that the command line option switch has been implemented since this post, such as:
    JLinkRTTLogger -Device NRF52 -If SWD -Speed 4000 -RTTChannel 0
    However, no sign of a stdout support, which might not be useful on Windows, but definitely a miss on Unix (either Linux or macOS) environment.
    Is the logger tool source code available (as part of the SDK for example) as I really need this kind of feature.
    Thanks.
    yes, the RTT logger src code is available as part of the J-Link SDK (Part No 8.08.06 on the price list).
