[SOLVED] JLink Daisychain
  • [SOLVED] JLink Daisychain
    I am trying to daisy chain three boards that have ARM ATMEL SAM4E16C chips on them. I have made a custom harness as per the guidelines in UM08001. So the system interconnections look as follows : Linux PC -> USB -> J Link Pro -> JTAG Connector Harness -> Daisy Chained boards. The aim is to program/communicate the three boards using a single JLink Pro. I have some queries to get this working:
    - Where can i enter the configuration details (IR Len, Position)
    - I do have MAC and IPs assigned to each of the boards. Will this help ?
    - I have also tried using Windows PC to do the same. But failed
    Please let me know if further information is required.
  • Hi ,
    Could you tell me to which section of the manual you are referring to?
    I assume you are using J-Link Commander (JLinkExe).
    It is possible to pass -JTAGConf <IRPre>,<DRPre> as a command line parameter.
  • HI Niklas,
    I am referring to the Section 5.3 of the manual for the JTAG scan chain.
    I am currently using a ubuntu machine.
    I tried running the JLinkExe with the command line paramater.
    But I am yet to ascertain if that is working.
    Bharath
  • Hi Niklas,
    I have some more queries on the JTAG daisychain
    a) I have created a daisychain harness as per the diagram in page 178. The ground pins (3,5) and VTref(1) are not connected. Do I need to connect them (Tried doing it, but did not work)
    b) Is there a way to communicate to a specific device in the daisychain ? Any JLinkExe command line options or through settings or via script file JlinkScriptFile. (in Linux)
    c) Does the JTAG configuration automatically switch over to a SWD mode ? When i powered on the daisy chain with 3 devices, it detected one device in SWD mode.
    Please let me know of additional input is required.
    Bharath
  • Hi Bharath,
    a) They have to be connected.
    From the questions b) and c) I assume you are using an old version of the J-Link software.
    The current J-Link software package is available free of charge here .
    A specific device in the chain can be chosen by passing "-JTAGConf <IRPre>,<DRPre>" as a command line parameter (works only with current versions!)
    As an alternative, "-jtagconf -1,-1" can be passed, then J-Link Commander will try to connect to the first device found in the chain that matches the device or core specified (specifying a device or at least a core is mandatory with current versions(5.10 or later) of the J-Link software)
