saving display contents to memory area
  • Hi Kerem,
    Maybe you are looking for something like the routine GUI_BMP_Serialize() (just search for it in the manual). In the manual we have a sample where we write to a file. But this should work also when writing the raw data directly to the memory. Just adapt the sample routines shown in the manual to your needs.
  • I found another way to achieve this, as serialize didn't seem to give me the result I wanted:
    create a memory device using GUI_MEMDEV_Create() - note it doesn't have to be the whole screen if you're memory constrained!
    Select it using GUI_MEMDEV_Select()
    Copy from the display into the memory device using GUI_MEMDEV_CopyFromLCD()
    Get a pointer to the memory device's data using GUI_MEMDEV_GetDataPtr() - returns a void pointer to the pixel data.
    Read out / copy the data from the memory device pointer.
    Clean up using GUI_MEMDEV_Select(0) and GUI_MEMDEV_Delete()
    I achieved a screen dump function by many iterations of this process, without ever having to store the whole screen.
  • Hi Ana,
    Try the code below. There I create a memory device and read the LCD content. Then I get a pointer to the memdev data, change the value where it points to and write back the changed memory device.
    1. #include "DIALOG.h"
    3. *
    4. * Defines
    5. *
    7. */
    9. *
    10. * Static data
    11. *
    12. **********************************************************************
    13. */
    14. /*********************************************************************
    15. *
    16. * Static code
    17. *
    18. **********************************************************************
    19. */
    20. /*********************************************************************
    21. *
    22. * _DrawSomething
    23. */
    24. static void _DrawSomething(void) {
    25. int xSize, ySize;
    26. int i;
    27. xSize = LCD_GetXSize();
    28. ySize = LCD_GetYSize();
    29. GUI_SetColor(GUI_RED);
    30. for (i = 0; i < ySize; i += 10) {
    31. GUI_DrawHLine(i, 0, xSize);
    32. }
    33. }
    34. /*********************************************************************
    35. *
    36. * Public code
    37. *
    38. **********************************************************************
    39. */
    40. /*********************************************************************
    41. *
    42. * MainTask
    43. */
    44. void MainTask(void) {
    45. GUI_MEMDEV_Handle hMem;
    46. U32 * pData;
    47. int x, y;
    48. int xSize, ySize;
    49. GUI_Init();
    50. //
    51. // Draw something on the screen
    52. //
    53. _DrawSomething();
    54. //
    55. // Create a memory device
    56. //
    57. hMem = GUI_MEMDEV_CreateFixed32(30, 30, 80, 80);
    58. //
    59. // Copy the LCD content correpsonding to the position and size of the memory device
    60. //
    61. GUI_MEMDEV_CopyFromLCD(hMem);
    62. //
    63. // Get a pointer to memory device data
    64. //
    65. pData = (U32 *)GUI_MEMDEV_GetDataPtr(hMem);
    66. xSize = GUI_MEMDEV_GetXSize(hMem);
    67. ySize = GUI_MEMDEV_GetYSize(hMem);
    68. for (y = 0; y < ySize; y++) {
    69. for (x = 0; x < xSize; x += 4) {
    70. //
    71. // Use the data pointer to change the content of the memory device
    72. //
    73. *(pData + x + (xSize * y)) = GUI_MAKE_COLOR(0x0000FF00);
    74. }
    75. }
    76. //
    77. // Write the changed memory device back to the screen with an offset
    78. //
    79. GUI_MEMDEV_CopyToLCDAt(hMem, 30, 5);
    80. while (1) {
    81. GUI_Delay(100);
    82. }
    83. }
    84. /*************************** End of file ****************************/
