Windows file extension associations - clicking A.jflash file to launch J-FlashARM with same project
  • Windows file extension associations - clicking A.jflash file to launch J-FlashARM with same project
    Hi Segger support,
    I have registered extension .jflash to open J-FlashARM. i.e. I have associated the extension with the application.
    Now I would like to be able to:
    1. Click on my project file 'A.jflash' and then J-FlashARM loads and A.jflash is the active project within the loaded J-FlashARM.
    2. I then close J-FlashARM
    3. Click on 'B.jflash' and the same happens except B.jflash is the active project.
    Is this possible?
    Andy
  • Hello Andy,
    this should be no problem.
    J-Flash remembers the last state it was before closing it.
    Example, you have the following files:
    data.bin
    a.jflash
    b.jflash
    Opening J-Flash with a.jflash
    Opening data.bin while J-Flash is still open
    Closing J-Flash
    Opening J-Flash with b.jflash
    J-Flash will open b.jflash + data.bin
  • Hi Alex,
    Thanks for the quick reply.
    I followed your instructions and it still doesn't work. Maybe my problem is with Windows XP and not J-Flash?
    As per your instructions this is what I did:
    My Documents>Tools>Folder Options>File Types>
    .HEX>Advanced>Edit>Open>JFlashARM.exe %1 (V402a)
    .jflash>Advanced>Edit>Open>JFlashARM.exe %1 (V402a)
    Open J-Flash with a.jflash - Opens but not with a.jflash (opens with the previous one opened via the file menu)
    Open data.hex while J-Flash is still open - Opens another window (we use .hex -same difference)
    Subsequently opening .flash or .hex just opens another window and never updates a current J-Flash in memory.
    I think this must be XP related?
    Any help would be appreciated.
    Many Regards
    Andy
  • Hi Alex,
    The problem was with Windows.
    For some reason the quotes had been removed from around the %1, i.e. should be "%1"
    The %1 is detailed within my previous reply, by the way.
    Hope this helps anyone else with the same problem.
    Andy
