problems with nrf52 DK (nRF52832_xxAA) and jlink
  • problems with nrf52 DK (nRF52832_xxAA) and jlink
    Hi.
    I'm trying to get Linux debugging and developement environment working for said Nordic chip. I can flash it with nordic tools and also with eclipse by makefile flash target (uses also said tools).
    However I cannot get any uart traces out of the system nor I can get the debugger to attach to HW. When I press the debug I can see the user thread for a second, before both nordic board SW apparently crashes and debugger reports terminated state (-1 returns for JLinkGDBServer and gdb & 0 for SWV). Also the disassembly window just says "no source available for 0x0". I've got only breakpoint in the start of the main-function.
    Just running the SW works just fine. SW in question is the BLE proximity example delivered in the SDK.
    So far I've done all the setup nordic recommends for jlink. I've also updated the Jlink firmware with jlinkexe.
    I've also tried getting the trace out of the situation. Occasionally I can see parts of the trace in the terminal, but most of the time nothing. Even in the cases I see short trace parts I cannot see them via Jlink SW (JLinkExe->connect->TStart says no trace clock). Uart clock is 38400 both in terminal and in SW.
    Help here would be appreciated.
    From debugger:
    " SEGGER J-Link GDB Server V5.10u Command Line Version
    JLinkARM.dll V5.10u (DLL compiled Mar 17 2016 19:06:19)
    GDBInit file: none
    Terminal I/O port: 2333
    Generate logfile: off
    Verify download: on
    Init regs on start: off
    Silent mode: off
    Single run mode: on
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: nRF52832_xxAA
    Target interface: SWD
    Target interface speed: 1000kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 15 2016 18:03:17
    Hardware: V1.00
    S/N: 682343799
    Checking target voltage...
    Target voltage: 3.30 V
    Listening on TCP/IP port 2331
    Connecting to target...Connected to target
    Reading all registers
    Read 1 bytes @ address 0x00000000 (Data = 0xC0)
    Reading 64 bytes @ address 0x00000000
    Reading 8 bytes @ address 0x00000000
    Reading 7 bytes @ address 0x00000000
    Target interface speed set to 1000 kHz
    Select auto target interface speed (1000 kHz)
    Flash breakpoints enabled
    Semi-hosting enabled (Handle on BKPT)
    Semihosting I/O set to TELNET Client
    SWO disabled succesfully.
    SWO enabled succesfully.
    Reading 64 bytes @ address 0x00023F00
    Read 1 bytes @ address 0x00023F11 (Data = 0xB5)
    R0 = 2000006B, R1 = 000000FC, R2 = E000E000, R3 = 000000FC
    R4 = 00000000, R5 = 000F0000, R6 = 00028000, R7 = 00000000
    R8 = 00000000, R9 = 00000000, R10= 1FFF8000, R11= 00000000
    R12= 00000001, R13= 20007F80, MSP= 20007F80, PSP= 00000000
    R14(LR) = 00003217, R15(PC) = 00004FDE
    XPSR 61000000, APSR 60000000, EPSR 01000000, IPSR 00000000
    CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    Setting breakpoint @ address 0x00023F11, Size = 4, BPHandle = 0x0001
    Starting target CPU...
    ...Breakpoint reached @ address 0x00023F10
    Removing breakpoint @ address 0x00023F11, Size = 4
    GDB closed TCP/IP connection"
    lsusb:
    Bus 004 Device 002: ID 8087:8000 Intel Corp.
    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 003 Device 002: ID 8087:8008 Intel Corp.
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 003: ID 138a:0017 Validity Sensors, Inc. Fingerprint Reader
    Bus 001 Device 002: ID 058f:9540 Alcor Micro Corp. AU9540 Smartcard Reader
    Bus 001 Device 010: ID 046d:c52e Logitech, Inc. MK260 Wireless Combo Receiver
    Bus 001 Device 078: ID 1366:1015 SEGGER
    Bus 001 Device 006: ID 5986:0268 Acer, Inc
    Bus 001 Device 005: ID 8087:07dc Intel Corp.
    Bus 001 Device 014: ID 1199:a001 Sierra Wireless, Inc.
    Bus 001 Device 009: ID 0557:2221 ATEN International Co., Ltd Winbond Hermon
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    dmesg | grep tty
    "[5036548.448084] cdc_acm 1-2:1.0: ttyACM1: USB ACM device"
    /etc/udev/rules.d/99-jlink.rules:
    ACTION!="add", SUBSYSTEM!="usb_device", GOTO="jlink_rules_end"ATTR{idProduct}=="1015", ATTR{idVendor}=="1366", MODE="666"
    LABEL="jlink_rules_end"
    We are not aware of any issue regarding tracing of nRF52 devices.
    Does this issue still persists with the current version of the J-Link software?
    If yes, could you please provide us with instructions and files necessary the reproduce the issue?
