[SOLVED] JLink and STM32F411CE problem
  • [SOLVED] JLink and STM32F411CE problem
    Hi all,
    I've a simple board to test STM32F411CE and a JLink Edu to program it through the SWD. I can connect to the host, but when it comes to programming the flash (I'm using Eclipse and the GNU plugin for ARM) I got errors like "Failed to prepare for programming", "Failed to execute RAMCode for RAM check", etc. I thought this could be the same error about WWDG-SW bit unset found here:
    [SOLVED] STM32F746 Failed to execute RAMCode for RAM check! after upgrade to jlink 5.02e
    But here are the option bytes and they seem to be correct:
    J-Link>connect
    Device "STM32F411CE" selected.
    J-Link>mem32 40023c0c 1
    ****** Error: Failed to prepare for programming.
    RAM check failed @ addr 0x200007B0.
    RAM check failed while testing 0x0450 bytes @ addr 0x200006F4.
    40023C0C = 00000000
    Found SWD-DP with ID 0x2BA01477
    CoreSight components:
    ROMTbl 0 @ E00FF000
    ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
    ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT
    ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB
    ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM
    ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU
    ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM
    Cortex-M4 identified.
    J-Link>mem32 1fffc000 4
    1FFFC000 = 5510AAEF 5510AAEF C0003FFF C0003FFF
    That is, AA (no read protection), E (no reset generated, SW watchdog, WWDG-SW set), F (BOR off).
    I've also read about testing the SWD connection with ST Link:
    [SOLVED] Bricking STM32F4 after failed programming
    Here a test I've done to understand what is going on (this is, resetting flash register Flash status register FLASH_SR and reading the value back again):
    JLinkExe -device STM32F411CE -if SWD -speed 1000
    SEGGER J-Link Commander V5.10u (Compiled Mar 17 2016 19:06:22)
    DLL version V5.10u, compiled Mar 17 2016 19:06:19
    Firmware: J-Link V9 compiled Mar 15 2016 18:03:32
    Hardware version: V9.30errors
    S/N: 2693047
    License(s): FlashBP, GDB
    OEM: SEGGER-EDU
    VTref = 3.338V
    J-Link>connect
    ROMTbl 0 @ E00FF000
    J-Link>r
    Reset delay: 0 ms
    J-Link>h
    PC = FFFFFFFE, CycleCnt = 00000000
    R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    R12= 00000000
    SP(R13)= FFFFFFFC, MSP= FFFFFFFC, PSP= 00000000, R14(LR) = FFFFFFFF
    XPSR = 01000000: APSR = nzcvq, EPSR = 01000000, IPSR = 000 (NoException)
    CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00
    FPU regs: FPU not enabled / not implemented on connected CPU.
    40023C0C = 00000000
    J-Link>mem32 0 1
    00000000 = FFFFFFFF
    J-Link>w1 0 1
    Writing 01 -> 00000000
    J-Link>mem32 0 1
    00000000 = FFFFFFFF
    J-Link>mem32 40023c0c 1J-Link>connect
    ROMTbl 0 @ E00FF000
    40023C0C = 00000080
    J-Link>w4 40023c0c 80
    Writing 00000080 -> 40023C0C
    40023C0C = 00000000
    J-Link>mem32 0 1
    00000000 = FFFFFFFF
    J-Link>w1 0 1
    J-Link>mem32 0 1
    00000000 = FFFFFFFF
    40023C0C = 00000080
    40023C0C = 00000000
    J-Link>w4 0 1
    Writing 00000001 -> 00000000
    J-Link>mem32 0 1
    00000000 = 00000001
    40023C0C = 00000000
    J-Link>mem32 200007ac 1
    200007AC = 000000B8
    J-Link>mem32 200007b0 1
    200007B0 = 000000BC
    J-Link>mem32 200007b4 1
    200007B4 = 000000C0
    J-Link>mem32 200007b8 1
    200007B8 = 000000C4
    Can someone help?
    Thanks in advance
    Andrew
  • Hi Andrew,
    I just checked tried to reproduce this issue with an Nucleo STM32F411RE here, but it works fine for me.
    Could you try to create a J-Link Commandfile that reliable reproduces this issue with your setup and post it here?
    Could you also post a J-Link logfile?
    Log output can be enabled like as follows:
    • Open a connection to J-Link, e.g start J-Link Commander
    • In J-Link Control Panel: (Click the J-Link symbol located in the notification / tray area in order to open J-Link Control panel)
    • Open the tab "Settings"
    • Next to the field "Log file" check "Override" and click "..." in order to choose a log file path.
    This is also described in UM8001 Chapter 5 "Working with J-Link and J-Trace", Section 5.7 "J-Link control panel" .
  • Dear Niklas,
    thanks for the support, I apologize for the very late reply but I didn't have time to verify what was wrong with my board.
    Since you confirmed the correct behaviour of J-Link, I've investigated the issue at PCB level and found that the cap for the internal regulator was not properly soldered.
    I can program the MCU, problem solved. :thumbsup:
    Andrew
    The post was edited 1 time, last by student47 ().
  • Hi Andrew,
    Thanks for confirmation and good to hear that you are up and running now!
