[SOLVED] Specifying bin file and start address for JFlash command line
  • [SOLVED] Specifying bin file and start address for JFlash command line
    I am attempting to use JFlash on the command line with a
    binary file. The following command does not work with a binary:
    1. .\Jflash.exe –openprjC:\project.jflash –openC:\dataFile.bin,0x100000
    I have tried it with a mot and the “-open” argument works
    fine:
    1. .\Jflash.exe –openprjC:\project.jflash –openC:\dataFile.mot
    The only way I have been able to open a bin file is to omit
    the “-open” altogether:
    1. .\Jflash.exe –openprjC:\project.jflash C:\dataFile.bin
    However, using this method I cannot specify the start
    address.
    The question is: how can I open a .bin file from the command
    line while specifying a start address?
    I just gave it a try and this command line works fine for me:
    1. "C:\Program Files (x86)\SEGGER\JLink_V511e\jflash.exe" -openprjC:\Work\Support\2016_Q1\TMS570LC4357ZWT_Forum2991\TMS570LC4357ZWT.jflash -openC:\Work\Support\2016_Q1\TMS570LC4357ZWT_Forum2991\InitialFlash.bin,0x100000
    This seems to be similar to your first example.
    Are the file you use actually located in the root dir of your C:\ drive? Maybe J-Flash/Windows do not like this (Although J-Flash should be fine with that)
    Is there an error message in the Logfile?
