OSDelay and OS_EVENT_WaitTimed result in HardFault
  • OSDelay and OS_EVENT_WaitTimed result in HardFault
    I am trying a few things out with the trial version on a LPC4357.
    I have downloaded embOS_CortexM_GCC_emIDE_Trial_V416.zip
    The example for NXP LPC4357 is working fine, and I am extending it now to test some stuff of my own.
    I enlarged the stack for HPTask and used it as starting point for my own code.
    My own code will create a thread, this already gave some problems, I disabled LPTask and the thread would go oserror 0x80 but after re-enable LPTask again it worked.
    In LPTask and HPTask I can do both OS_Delay without any problem, but in the thread I created myself inside HPTask if I execute OS_Delay it gives a hardfault.
    I temporarily fixed this by using OS_Delayus which works without any problems.
    Then the second issue I came across is that OS_EVENT_WaitTimed will end up in the hardfault handler with following stacktrace:
    1. Thread #1 (Suspended : Signal : SIGTRAP:Trace/breakpoint trap) HardFaultHandler() at SEGGER_HardFaultHandler.c:209 0x1a00d1b6 () at 0xfffffffd 0x40045000 OS_InsertTask() at 0x1a00fece 0x200 0x200
    I guess this maybe has to do something with the same problem as OS_Delay.
    Am I forgetting something, or using something in the wrong way?
    Cheers,
    Gerard
  • Dear Gerard,
    Could you please share your code with us?
    OS Error 0x80 indicates that you tried to create a task with a task control block which was already used for another task.
    I guess you did something wrong when creating you thread.
    Please be aware that you need a separate task control block and task stack for your thread.
    Could you please run our sample application OS_EventObject.c? It shows how to use event objects.
    Yes, I think so ;) .
    Please share your code here or contact us directly per email.
    Such things work out of the box with embOS, therefore it should be easy to solve this issue.
    Til
  • Dear Til,
    Thank you for your quick answer.
    I am porting a library to see if it will work with your OS.
    This library has an OSAL layer where it creates a thread, one thread only at the moment.
    This I did in the following way:
    1. /* Global stack pointer, currently only 1 thread created */
    2. static void *pStackWifi;
    3. QOSAL_STATUS qosal_task_create(QOSAL_VOID Task(QOSAL_VOID*), char *task_name, int stack_size, QOSAL_VOID *param, unsigned long task_priority, qosal_task_handle *task_handle, QOSAL_BOOL auto_start) {
    4. QOSAL_STATUS osal_ret = QOSAL_ERROR;
    5. /* I have created a memory pool on my external sdram, get a block */
    6. pStackWifi = OS_MEMF_Alloc(&extramHeap,1);
    7. if(pStackWifi != NULL) {
    8. /* Create the task in the block on sdram and pass parameters to the task */
    9. OS_CreateTaskEx(task_handle,task_name,task_priority,Task,pStackWifi,SDRAM_BLOCKSIZE,2u,param);
    10. if(task_handle != NULL)
    11. osal_ret = QOSAL_OK;
    12. }
    13. return osal_ret;
    14. }
    For the events I will check the example of the EventObject.c, thank you for the pointer.
    Cheers,
    Gerard
  • Hi Gerard,
    your code snippet looks basically ok, but the issue could be located somewhere else.
    If you like you could send us your complete project and we will have a look in it.
    Please find the embOS support email address in the embOS manual in chapter "Support", segger.com/downloads/embos/UM01001_embOS.pdf.
    Til
