I'm just designing a board and was going to put a connection on the debug header for Target Power (which my JLink supports and I've tested).
Is it ok to have Target Power connected in the case the board is self-powered or otherwise externally powered? I was intending on connecting Target Power direct to VCC (5V) on the board so I can power the entire thing through the debug connector when testing, my concern is that when in production, where the board will have an external 5V supply supplying VCC, if I then plug in the JLink I'm supplying 5V to pin 19 (Target Power) instead of sourcing it. Do the JLinks have internal protection against this?
