[SOLVED] Jlink - hot plug - attach or unattach to target - correct method
  • [SOLVED] Jlink - hot plug - attach or unattach to target - correct method
    Gday all
    I have an NXP lpc1768 running on a custom board with a 10 pin cortex jtag connector.
    I have Jlinkgdbserver running and whenever I connect or remove the jtag connector either jlinkexe or jlinkgdbserver lose connection to the target.
    How can I have this connection maintained? Sometimes the fix results in me having to unplug the usb port on the jlink to reset the jlink. Sometimes I will get the error message in the gdb server.
    Error: Emulator out of memory
    When I unplug the jtag connector for the target.
    I understood that it was possible to attach/deattach to a running target but my experience tells me that it won't work.
    Cheers!
    Paul
  • Hi Paul,
    if you want to maintain your connection to the target, simply do not disconnect it.
    If you really need to physically reconnect the device, you can stop the GDB Server/Commander before disconnecting it and restart it when you have reconnected it.
    Resetting the J-Link should not be needed, if you do it that way.
    Arne
