Thread Awareness for FreeRTOS
  • Thread Awareness for FreeRTOS
    could you please provide an implementation example for the Thread Awareness for FreeRTOS?
    I don't feel like I have enough understanding of the JS backend to write it myself.
    Consider this would be done. Could a access the stack back trace of every thread ?
    Please find the script for Cortex-M3 and Cortex-M4F attached (rename to*.js).
    The scripts require FreeRTOS to be compiled such
    that the referenced symbols do not have static qualifier (so the
    debugger can access them).
    So if the script does not work, have a look at it and make sure the symbols can be accessed.
    Yes, the call stack can be accessed when double-clicking on a task.
    Johannes
    • threads_CM3.txt
      (2.46 kB, downloaded 942 times, last: )
    • threads_CM4F.txt
      (2.64 kB, downloaded 1,162 times, last: )
  • Can anybody provide a step-by-step instruction how to use these scripts withSegger Jlink gdbserver. I am a Segger beginner but have some experience with OpenOCD and Blackmagic debug probe.
    Are there more scripts for other RTOSes?
    Any repository for those scripts?
    Does such a script already exist for NutOS (ethernut.de/)?
  • Embedded Studio is independent from GDB Server and uses its own scripts for OS awareness.
    There will be OS awareness in J-Link GDB Server in the future, too.
    Currently you could use OpenOCD with J-Link.
    Johannes
