SystemView system description string
  • SystemView system description string
    I am currently evaluating SystemView for FreeRTOS. Up to now I got everything up and running. By chance I noticed, that SystemView is updating system description defined in _cbSendSystemDesc(void) approximately every 5s. I am wondering if this periodic update is required?
    I checked this behavior by adding the following "debug" code to _cbSendSystemDesc(void):
    static void _cbSendSystemDesc(void) {
    GPIOB_PDOR ^= GPIO_PIN(17)
    // SysView application and device description
    SEGGER_SYSVIEW_SendSysDesc("N="SYSVIEW_APP_NAME"");
    SEGGER_SYSVIEW_SendSysDesc("O=FreeRTOS");
    SEGGER_SYSVIEW_SendSysDesc("D="SYSVIEW_DEVICE_NAME"");
    SEGGER_SYSVIEW_SendSysDesc("C="SYSVIEW_CORE_NAME"");
    // SysView interrupt description.
    SEGGER_SYSVIEW_SendSysDesc("I#15=SysTick");
    Regards, Philipp
  • Hi Philipp,
    Yes, this periodic update is required to be able to properly analyze recordings which do not start at the beginning.
    We might make the update period configurable in a future version of SystemViewer.
    Johannes
  • Hi Johannes,
    thanks for the fast reply. Since this periodic update is required, the function calls in _cbSendSystemDesc(void)should be minimized to ensure real time requirements are met.
    Philipp
  • Hi Philipp,
    The config file is subject to user's changes,
    so feel free to modify it to merge the SEGGER_SYSVIEW_SendSysDesc() calls.
    Make sure that the string length per call does not exceed 128 characters.
    Johannes
