How to rotate a text insode a window?
  • How to rotate a text insode a window?
    I am Windows Manager and I have a window fully populated.
    I would like to rotate some text boxes widgets. I believe they do not support the rotation method.
    I saw at the manual that we can use "rotated" texts, as follows:
    GUI_RECT Rect = {166+(18)*1, 72, 40, 80};
    char acText[] = "Rotated\ntext";
    GUI_SetTextMode(GUI_TM_XOR);
    GUI_FillRectEx(&Rect);
    GUI_DispStringInRectEx(acText, &Rect, GUI_TA_HCENTER | GUI_TA_VCENTER, strlen(acText), GUI_ROTATE_CCW);
    However, this piece of code is not working at my window: it does not shows up. Is it incompatible with WM?
    Any hint of how to solve this issue?
    Thanks.
  • Hello Ajax,
    I have written a small sample which shows how to draw rotated text and how to overwrite a callback.
    1. #include <string.h>
    2. #include "DIALOG.h"
    3. /*********************************************************************
    4. *
    5. * Static code
    6. *
    7. **********************************************************************
    8. */
    9. /*********************************************************************
    10. *
    11. * _cbWin
    12. */
    13. static void _cbText(WM_MESSAGE * pMsg) {
    14. GUI_RECT Rect;
    15. char aBuffer[255];
    16. switch (pMsg->MsgId) {
    17. case WM_PAINT:
    18. //
    19. // Fill window with fancy red
    20. //
    21. GUI_SetBkColor(GUI_RED);
    22. GUI_Clear();
    23. //
    24. // Get the area of the client, in this case the text widget
    25. //
    26. WM_GetClientRect(&Rect);
    27. //
    28. // Receive the text previously set while creating the widget
    29. //
    30. TEXT_GetText(pMsg->hWin, aBuffer, sizeof(aBuffer));
    31. //
    32. // Display rotated text inside a rectangle (the client one)
    33. //
    34. GUI_DispStringInRectEx(aBuffer, &Rect, GUI_TA_HCENTER | GUI_TA_VCENTER,
    35. strlen(aBuffer), GUI_ROTATE_CCW);
    36. break;
    37. default:
    38. //
    39. // Call the default callback just in case something else has to be done
    40. //
    41. TEXT_Callback(pMsg);
    42. }
    43. }
    44. /*********************************************************************
    45. *
    46. * Public code
    47. *
    48. **********************************************************************
    49. */
    50. /*********************************************************************
    51. *
    52. * MainTask
    53. */
    54. void MainTask(void) {
    55. WM_HWIN hItem;
    56. GUI_RECT Rect;
    57. char acText[] = "Text";
    58. GUI_Init();
    59. //
    60. // Define rectangle to draw text in
    61. //
    62. Rect.x0 = 0;
    63. Rect.y0 = 0;
    64. Rect.x1 = 100;
    65. Rect.y1 = 100;
    66. //
    67. // Draw a back ground
    68. //
    69. GUI_DrawGradientH(0, 0, LCD_GetXSize(), LCD_GetYSize(), GUI_DARKGRAY, GUI_GRAY);
    70. //
    71. // Set Text and set text mode to transparent
    72. //
    73. GUI_SetFont(&GUI_Font32B_1);
    74. GUI_SetTextMode(GUI_TM_TRANS);
    75. //
    76. // Dispplay a string inside a rectangle, rotated 90 degrees ccw
    77. //
    78. GUI_DispStringInRectEx(acText, &Rect, GUI_TA_HCENTER | GUI_TA_VCENTER, strlen(acText), GUI_ROTATE_CCW);
    79. //
    80. // Create a TEXT widget and overwrite its callback
    81. //
    82. hItem = TEXT_Create(100, 0, 100, 100, 0, WM_CF_SHOW, acText, GUI_TA_HCENTER | GUI_TA_VCENTER);
    83. WM_SetCallback(hItem, _cbText);
    84. while (1) {
    85. GUI_Delay(100);
    86. }
    87. }
    For further information on how to overwrite a callback please refer to the emWin user manual (UM03001_emWin5.pdf) chapter 18.2.3 "Overwriting callback functions".
