[SOLVED] JTAG Connection Problem: (SAM-ICE, SAM4SD32, JLink V5.10l)
  • [SOLVED] JTAG Connection Problem: (SAM-ICE, SAM4SD32, JLink V5.10l)
    I've got a Problem with getting Access to the Development-Board.
    My Hardware is:
    SAM-ICE, Board: SAM4S - EK2 (SAM4SD32)
    I've used the following Software:
    Atmel Studio 6.2, Atmel Studio 7.0, JLink V5.10l, JFlash V5.10l
    The Board was used before and is not at "Factory Defaults".
    When I try to connect with JLink, that's the Result:
    [img]http://www.korschin.de/Studium/screenshot001.png[/img]
    and the log-file:
    SEGGER J-Link V5.10l Log File
    DLL Compiled: Feb 11 2016 18:55:09
    Logging started @ 2016-02-23 10:19
    T1AFC 000:000 JLINK_GetDLLVersion() returns 51012 (0000ms, 0000ms total)
    T1AFC 000:000 JLINK_GetCompileDateTime() (0000ms, 0000ms total)
    T1AFC 000:000 JLINK_SelectUSB(Port = 0) returns 0x00 (0000ms, 0000ms total)
    T1AFC 000:000 JLINK_SetWarnOutHandler(...) (0000ms, 0000ms total)
    T1AFC 000:000 JLINK_OpenEx(...)
    Firmware: J-Link ARM V8 compiled Aug 26 2015 15:08:21
    Hardware: V8.00
    S/N: 28011512
    OEM: SAM-ICE
    Feature(s): RDI, GDB returns O.K. (0028ms, 0028ms total)
    T1AFC 000:028 JLINK_GetFirmwareString(...) (0000ms, 0028ms total)
    T1AFC 000:028 JLINK_GetHardwareVersion() returns 0x13880 (0000ms, 0028ms total)
    T1AFC 000:028 JLINK_EMU_HasCapEx(0x00000026) returns 0x00 (0000ms, 0028ms total)
    T1AFC 000:028 JLINK_EMU_GetProductId() (0000ms, 0028ms total)
    T1AFC 000:028 JLINK_GetFirmwareString(...) (0001ms, 0029ms total)
    T1AFC 000:029 JLINK_GetEmuCaps() returns 0xF9FF7BFF (0000ms, 0029ms total)
    T1AFC 000:029 JLINK_GetHWStatus(...) returns 0x00 (0001ms, 0030ms total)
    T1AFC 011:331 JLINK_Api_MRU_GetList()JLINK_ConfigJTAG(IRPre = -1, DRPre = -1) (0000ms, 0030ms total)
    T1AFC 023:900 JLINK_ExecCommand("device=ATSAM4SD32C", ...)Device "ATSAM4SD32C" selected. returns 0x00 (0002ms, 0032ms total)
    T1AFC 023:902 JLINK_SetSpeed(4000) (0003ms, 0035ms total)
    T1AFC 023:905 JLINK_EnableLog(...) (0000ms, 0035ms total)
    T1AFC 023:905 JLINK_GetEmuCaps() returns 0xF9FF7BFF (0000ms, 0035ms total)
    T1AFC 023:905 JLINK_TIF_GetAvailable(...) (0002ms, 0037ms total)
    T1AFC 023:907 JLINK_TIF_Select(JLINKARM_TIF_JTAG) returns 0x00 (0010ms, 0047ms total)
    T1AFC 023:917 JLINK_Connect() >0x2F8 JTAG>TotalIRLen = ?, IRPrint = 0x..000000000000000000000000 >0x30 JTAG> returns 0x01 (0005ms, 0052ms total)
    T1AFC 023:922 JLINK_GetIdData(...) >0x2F8 JTAG>TotalIRLen = ?, IRPrint = 0x..000000000000000000000000 >0x30 JTAG> (0004ms, 0056ms total)
    I've also tried to Start with some Atmel Example-Projects for this Board "Getting-Started Application on SAM-SAM4S-EK", but it failed.
    [img]http://www.korschin.de/Studium/screenshot002.png[/img]
    Maybe you have got an idea what's the problem here....
    Thanks a lot in advance.
    Oliver
  • Hi Oliver,
    good to hear that your setup is now in a working state.
