I'm working with STEmWin V5.28 with an SSD1351 Oled display. 8 bit parallel interface.
I've configured the Flex driver like this (removed some irrelevant code lines)
On Init the driver writes to the register 0xA0 a value of 0x00, which is the wrong value.
Referring here:
hpinfotech.ro/SSD1351.pdf
Register 0xA0 bits 7:6 set the colour depth. 00b is 256 colour, despite the driver being set for 565. The correct value is 01b for 65K colour.
Also for my display bit 5 needs to be set (enable COMsplit odd even) and bit 4 to be set (scan from COM[N-1} to COM0.)
So my display works with a value of 0x70.
I've hacked my code to intercept that register write and change the value, but is there something with my configuration that is causing this?
Thanks.
Referring here:
Thanks.
