[SOLVED] Systemview FREERTOS INCLUDE_pxTaskGetStackStart
  • [SOLVED] Systemview FREERTOS INCLUDE_pxTaskGetStackStart
    In systemview documentation is recommended to include INCLUDE_pxTaskGetStackStart in FreeRTOSconfig.h. This will cause inclusion "pStack = pxTaskGetStackStart(pxTaskStatusArray[x].xHandle);" in file SEGGER_SYSVIEW_FreeRTOS.c, such function is defined as extern. However such function is not available in FreeRTOS source files.
    How to correctly initialize start of stack in such a case? What do you recommend? I am using 8.2.3 version of stack.
    rum
    pxTaskGetStackStart is added with the FreeRTOS patch for SystemView.
    You can either apply the patch to your FreeRTOS Source, or use the current version V2.30,
    which does not require pxTaskGetStackStart.
    Johannes
