[SOLVED] Systemview cannot detect RTT buffer location
  • [SOLVED] Systemview cannot detect RTT buffer location
    If I leave automatic detection ON, buffer is not found. If I specify my RAM range (on xmc4500) as 0x1fffc000-0x2001000 again buffer is not found. Only if I give exact address (my case 0x20004e0 buffer is detected. Is there any reason why buffer is not detected? What I am doing wrong? For JlinkRTTwiever I have specified range in script file as SetRTTSearchRanges(0x1FFFC000,0x14000) and included scriptfile through Jlink control panel and it is working fine. Can systemview use same script file?
    rum
    The syntax for the search range is <Address> <Size> (0x1FFFC000 0x14000).
    The current version shows the correct syntax in the configuration dialog.
    Could you try this?
    Johannes
