[SOLVED] Issue about GUI_BMP_DrawScaledEx()
  • [SOLVED] Issue about GUI_BMP_DrawScaledEx()
    I draw a bitmap size of 80x60 successfully using GUI_BMP_DrawEx();
    then I try to scale & draw it using GUI_BMP_DrawScaledEx(), but failed.
    I use the same get data function for this two drawing functions.
    The emWin version what I use is v5.3. As follows:
    a) GUI_BMP_DrawEx(_GetData, &hFile, 0, 0);//draw directly
    b) GUI_BMP_DrawScaledEx(_GetData, &hFile, 0, 0, 4, 1);//draw by scaling 4x
    The size of bitmap file pointed by hFile is: 80x60;
    a) will be all right, and call _GetData() about 62 times;
    b) will be failed, and call _GetData() only once.
    And, look up the the guide UM03001 User & Reference Guide for emWin V5.32,
    it doesn't pointer out whether different get data functions should be used.
    My question is, should I use different get data functions?
    If so, how should I modify the current get data function offered by the guide?
    What the differences the two get data functions act as?
    Thanks.
    Best regards.
    The post was edited 3 times, last by kenmux ().
