Hello all,
i'm really new to Segger products and i have two little questions about the software products J-Flash and J-Link Commander.
Actually we are using J-Link Plus with the J-Link Commander (Batch- and CommanderScript-File) to flash devices in production process.
If i call the Batch-File, J-Link commander take down the CommandScript-File. In parallel the J-Link Flash Download window opens and show the actual progress of (compare,erase,program,verify). In the J-Link - Control panel in the tab Seetings-Flash download i can adjust different options for the compare(skip,CRC,readback,fastest method)- and very(Skip,..)-process. Are these options used by the commands erase,loadbin and verifybin in my commandScript-File?
CommandScript-File example:
erase
loadbin Fir.bin, 0x00
verifybin Fir.bin, 0x00
I'm a litlte bit confused.I read here segger.com/jlink-flash-download.html the chapter "Download into flash memory for development purposes" - I understood that i should use JFlash with Flasher in production purpose and not J-Link Commander. Is that right? Are there difference in verification-,programming- or the erase-process?
Best Regards,
Arne
erase
Best Regards,
Arne
