We are developing an IC using a "standard" ARM cortex M0. I am trying to simulate the digital design and also emulate the same design in an FPGA. To test the M0 debug ability I have tried to use Keil, the Segger standalone tools, etc but without a successful connection.
According to our designers, this ARM core requires the standard line reset (50+ clocks with SWDIO high) but also requires one or two more clocks with SWDIO low prior to reading the device ID (or anything else). I have tried the Segger tools with various M0 device variants and they all appear to just do the 50 clocks with SWDIO high and then either try the JTAG-to-SWD switch pattern or reading the ID without the extra 1 or 2 clocks with SWDIO low first.
Is it possible to manually control the insertion of the extra SWDIO low cycles? Is there a specific device setting I can try that has this?
The ARM serial debug documentation also eludes to this line reset requirement in section 4.4 of the "ARM Debug Interface Architecture Specification ADIv5.0 to ADIv5.2":
4.4.3 Connection and line reset sequence
A debugger must use a line reset sequence to ensure that hot-plugging the serial connection does not result in
unintentional transfers. The line reset sequence ensures that the SW-DP is synchronized correctly to the header that
signals a connection.
The SWD interface does not include a reset signal. A line reset is achieved by holding the data signal HIGH for at
least 50 clock cycles, followed by at least two idle cycles. Figure 4-8 shows the interface timing for a line reset
followed by a DP DPIDR register read.
Any help would be greatly appreciated.
Kevin
Kevin
