[SOLVED] RTT printf implementation bug
  • [SOLVED] RTT printf implementation bug
    Using V5.10c Software for OS X with my J-Link first of all I'm missing the RTT files in the Samples folder (at least here it is stated it should be there).
    I'm not sure where I got my RTT files from, but they are V210.
    But the real problem is the bad quality of the printf-implementation. Running the printf-test I get the following output:
    1. SEGGER Real-Time-Terminal Sample
    2. ###### Testing SEGGER_printf() ######
    3. printf Test: %c, 'S' : S.
    4. printf Test: %5c, 'E' : E.
    5. printf Test: %-5c, 'G' : G.
    6. printf Test: %5.3c, 'G' : G.
    7. printf Test: %.3c, 'E' : E.
    8. printf Test: %c, 'R' : R.
    9. printf Test: %s, "RTT" : RTT.
    10. printf Test: %s, "RTT\r\nRocks." : RTT
    11. Rocks..
    And that's it. All other format specifier's are never printed. So looking into the code I am not sure whats a fix for the bug, because the source code is very chaotic at least in my opinion. But the following line is definitly a bug (for example in _PrintUnsigned l.179):
    1. while (((v / Digit) >= Base) || (NumDigits > 1u)) {
    2. NumDigits--;
    3. Digit *= Base;
    4. }
    NumDigits is unsigned and could be zero. So during the first iteration NumDigits = 4294967295...
    Probably lines 148-153 are also problematic because Width is never ever used after these lines....
    I don't want to waste more time debugging the printf-functions, because these are a advertised features so they should work.
    Thanks in Advance
    BTW, it would be nice to have these files hosted on a public git server, so you could add a submodule to your git-controlled own project and get upstream updates very easily. Really pleasant, that ARM did the same to CMSIS this year (github.com/ARM-software/CMSIS).
    Currently the RTT files are only part of the Windows version.
    We will make sure the RTT files will be in the samples folder of the OS X version, too, and that SEGGER_RTT_Printf is working.
    We will think about making them available in a repository,
    but currently the J-Link Software Package is the only source for the RTT files.
    Johannes
    I have downloaded the new V511b package and the printf-implementation is working much better now. The output I get now is:
    11. Rocks..
    12. printf Test: %u, 12345 : 12345.
    13. printf Test: %+u, 12345 : 12345.
    14. printf Test: %.3u, 12345 : 12345.
    15. printf Test: %.6u, 12345 : 012345.
    16. printf Test: %6.3u, 12345 : 12345.
    17. printf Test: %8.6u, 12345 : 012345.
    18. printf Test: %08u, 12345 : 00012345.
    19. printf Test: %08.6u, 12345 : 012345.
    20. printf Test: %0u, 12345 : 12345.
    21. printf Test: %-.6u, 12345 : 012345.
    22. printf Test: %-6.3u, 12345 : 12345 .
    23. printf Test: %-8.6u, 12345 : 012345 .
    24. printf Test: %-08u, 12345 : 12345 .
    25. printf Test: %-08.6u, 12345 : 012345 .
    26. printf Test: %-0u, 12345 : 12345.
    27. printf Test: %u, -12345 : 4294954951.
    28. printf Test: %+u, -12345 : 4294954951.
    29. printf Test: %.3u, -12345 : 4294954951.
    30. printf Test: %.6u, -12345 : 4294954951.
    31. printf Test: %6.3u, -12345 : 4294954951.
    32. printf Test: %8.6u, -12345 : 4294954951.
    33. printf Test: %08u, -12345 : 4294954951.
    34. printf Test: %08.6u, -12345 : 4294954951.
    35. printf Test: %0u, -12345 : 4294954951.
    36. printf Test: %-.6u, -12345 : 4294954951.
    37. printf Test: %-6.3u, -12345 : 4294954951.
    38. printf Test: %-8.6u, -12345 : 4294954951.
    39. printf Test: %-08u, -12345 : 4294954951.
    40. printf Test: %-08.6u, -12345 : 4294954951.
    41. printf Test: %-0u, -12345 : 4294954951.
    42. printf Test: %d, -12345 : -12345.
    43. printf Test: %+d, -12345 : -12345.
    44. printf Test: %.3d, -12345 : -12345.
    45. printf Test: %.6d, -12345 : -012345.
    46. printf Test: %6.3d, -12345 : -12345.
    47. printf Test: %8.6d, -12345 : -012345.
    48. printf Test: %08d, -12345 : -0012345.
    49. printf Test: %08.6d, -12345 : -012345.
    50. printf Test: %0d, -12345 : -12345.
    51. printf Test: %-.6d, -12345 : -012345.
    52. printf Test: %-6.3d, -12345 : -12345.
    53. printf Test: %-8.6d, -12345 : -012345 .
    54. printf Test: %-08d, -12345 : -12345 .
    55. printf Test: %-08.6d, -12345 : -012345 .
    56. printf Test: %-0d, -12345 : -12345.
    57. printf Test: %x, 0x1234ABC : 1234ABC.
    58. printf Test: %+x, 0x1234ABC : 1234ABC.
    59. printf Test: %.3x, 0x1234ABC : 1234ABC.
    60. printf Test: %.6x, 0x1234ABC : 1234ABC.
    61. printf Test: %6.3x, 0x1234ABC : 1234ABC.
    62. printf Test: %8.6x, 0x1234ABC : 1234ABC.
    63. printf Test: %08x, 0x1234ABC : 01234ABC.
    64. printf Test: %08.6x, 0x1234ABC : 1234ABC.
    65. printf Test: %0x, 0x1234ABC : 1234ABC.
    66. printf Test: %-.6x, 0x1234ABC : 1234ABC.
    67. printf Test: %-6.3x, 0x1234ABC : 1234ABC.
    68. printf Test: %-8.6x, 0x1234ABC : 1234ABC .
    69. printf Test: %-08x, 0x1234ABC : 1234ABC .
    70. printf Test: %-08.6x, 0x1234ABC : 1234ABC .
    71. printf Test: %-0x, 0x1234ABC : 1234ABC.
    72. printf Test: %p, &_Cnt : 20000D1C.
    73. ###### SEGGER_printf() Tests done. ######
    But obviously this output is not really perfect. Maybe further bugfixing should be done.
    Besides, the RTT-files are not included in the OS X package. I have to get the Windows one to test the new implementation.
