Altering the Listbox spawned by a Dropdown Widget
  • Altering the Listbox spawned by a Dropdown Widget
    In order to fit the overall visual scheme of my GUI I need to alter the Listboxes that are spawned by my Dropdowns. After an attempt to set a new owner draw function for a listbox failed I tried a sanity check that also doesn't seem to be working. Under WM_INIT_DIALOG I have:
    hItem = WM_GetDialogItem(pMsg->hWin, ID_DROPDOWN_0);
    DROPDOWN_SetListHeight(hItem, 34*DROPDOWN_GetNumItems(hItem));
    DROPDOWN_SetTextHeight(hItem, 40);
    DROPDOWN_Expand(hItem);
    lBox = DROPDOWN_GetListbox(hItem);
    LISTBOX_SetBkColor(lBox, LISTBOX_CI_UNSEL, 0x00201F13);
    with hItem being defined as a WM_HWIN and lBox defined as a LISTBOX_Handle. I have also attempted to set the default background color of all Listbox widgets to no avail. As this Listbox doesn't show up expanded when the GUI is drawn I had thought maybe I was executing this command at a time when it was essentially non-functional, but DROPDOWN_GetListbox(hItem) seems to get a value when called after it. I also wasn't sure if the Handle received persists between each expansion of the Dropdown, or if perhaps a new Listbox widget is created each time.
    These Listboxes are alterable, correct? Am I simply attempting to alter them at the wrong time?
    Thank you,
    Tyler
  • Hi Tyler,
    As already communicated via mail the listbox of a dropdown could be altered like shown in the sample.
    Regards, Jörg
