Hi
I have a problem with loading an .elf file. The Debugger crashes while loading the .elf, caused by a buffer overflow. This error occurs using the version 1.78 on Windows, 1.79a 64Bit on Windows and 1.79a 64Bit on Linux. The .elf file is about 3.3MB of size and is compiled with GCC 4.8 for embedded arm. Another .elf file using the same compiler (and the same compiler flags as far as I'm aware) does work just fine. That file is only 2.1MB in size.
If you want to have a look at the .elf file (as I assume you do), I have to get a release for it by my supervisors because it's proprietary code. And I can send it only by private ways, posting it here won't be possible.
To start with, I can provide the following callstacks from both windows and linux:
Callstack Windows:
> msvcr100.dll!00000000647e4930() Unknown
J-Link Debugger.exe!000000013fdafd6a() Unknown
J-Link Debugger.exe!000000013fd9c8e8() Unknown
J-Link Debugger.exe!000000013fda22c8() Unknown
J-Link Debugger.exe!000000013fda2e55() Unknown
J-Link Debugger.exe!000000013fda2fe7() Unknown
J-Link Debugger.exe!000000013fda2f4e() Unknown
J-Link Debugger.exe!000000013fda3473() Unknown
J-Link Debugger.exe!000000013fda498d() Unknown
J-Link Debugger.exe!000000013fda4d02() Unknown
J-Link Debugger.exe!000000013fd71ce3() Unknown
J-Link Debugger.exe!000000013fcbb74a() Unknown
J-Link Debugger.exe!000000013fcbe8f6() Unknown
J-Link Debugger.exe!000000013fcba7e4() Unknown
QtCore4.dll!0000000064909972() Unknown
QtCore4.dll!0000000064918567() Unknown
msvcr100.dll!0000000064791d9f() Unknown
msvcr100.dll!0000000064791e3b() Unknown
kernel32.dll!000000007754652d() Unknown
ntdll.dll!000000007767c521() Unknown
Callstack Linux:
*** buffer overflow detected ***: ./JLinkDebugger terminated
======= Backtrace: =========
/lib64/libc.so.6(+0x712df)[0x7fb476c642df]
/lib64/libc.so.6(__fortify_fail+0x37)[0x7fb476ce9e17]
/lib64/libc.so.6(+0xf4f90)[0x7fb476ce7f90]
/lib64/libc.so.6(+0xf40eb)[0x7fb476ce70eb]
./JLinkDebugger[0x61ac10]
./JLinkDebugger[0x61b068]
./JLinkDebugger[0x61b22a]
./JLinkDebugger[0x6184f7]
./JLinkDebugger[0x6185dd]
./JLinkDebugger[0x618589]
Callstack Windows:
Callstack Linux:
