Enable Trace Feature: #define OS_LIBMODE_DT
  • Enable Trace Feature: #define OS_LIBMODE_DT
    I want print the CPU load for all used tasks and how often tasks run. (embOS 3.82k)
    I have enable in the file OS_Config.h:
    //#define OS_LIBMODE_R
    //#define OS_LIBMODE_D
    #define OS_VIEW_ENABLE 1
    When I compile comes this errors:
    /embOS/GenOSSrc/OSTrace.c(189) : undefined reference to `OS_COM_StoreOutU8'
    /embOS/GenOSSrc/OSTrace.c(272) : undefined reference to `OS_COM_GetInU16'
    /embOS/GenOSSrc/OSTrace.c(173) : undefined reference to `OS_COM_StoreOutU16'
    /embOS/GenOSSrc/OSTrace.c(180) : undefined reference to `OS_COM_StoreOutU32'
    In your documentation "UM01001_embOS_Generic.pdf" are not documented this routines.
    For what need I this routines?
    How should I use this?
    Or gives a other way to print the CPU load for every task without activate OS_LIBMODE_DT?
    Thank you very much.
    Regards Markus
  • RE: Enable Trace Feature: #define OS_LIBMODE_DT
    Dear Markus,
    These routines are implemented in a seperate module, OSCom.c. If you kept the structure of the shipping, OSCom.c should be located at /embOS/GenOSSrc/ as well.
    If you want me to, you may also tell me which port of embOS you are using, so I can double-check for these routines in your most recent shipment.
    The routines are used to access the buffer for embOSView communication. They are merely used internally and therefore aren't described in the manual.
    Please tell me if I can be of further help.
    Martin
