[SOLVED] STM32F746 Failed to execute RAMCode for RAM check! after upgrade to jlink 5.02e
  • [SOLVED] STM32F746 Failed to execute RAMCode for RAM check! after upgrade to jlink 5.02e
    I have a STMF746 board that i was connecting to, via Jtag, using jlink/jlink GDB 5.02b.
    I have just upgraded to 5.02e and now cannot programme or debug the STM32F746. Also I tried to go back to using 5.02b but this will not work for me anymore either.
    When I upgraded to 5.02e the jlink firmware updated to:
    Firmware: J-Link V9 compiled Sep 18 2015 19:53:12
    Hardware: V9.20
    I get this error in the log:
    ERROR: Failed to prepare for programming.
    Can anyone explain what "RAMCode" is? Is this a new jlink feature?
    Gregor Bruce
    This is the GDB server log
    Listening on TCP/IP port 2331
    Connecting to target...
    J-Link found 2 JTAG devices, Total IRLen = 9
    JTAG ID: 0x5BA00477 (Cortex-M4)
    Connected to target
    Reading all registers
    Read 4 bytes @ address 0x08000200 (Data = 0x4A32B5F8)
    Resetting target
    Downloading 1560 bytes @ address 0x08000000
    Downloading 4096 bytes @ address 0x08008000
    Downloading 4096 bytes @ address 0x08009000
    Downloading 4096 bytes @ address 0x0800A000
    Downloading 4096 bytes @ address 0x08043000
    Downloading 4096 bytes @ address 0x08044000
    Downloading 823 bytes @ address 0x08045000
    Downloading 8 bytes @ address 0x08045338
    Downloading 3968 bytes @ address 0x08045340
    Downloading 456 bytes @ address 0x20000000
  • Hi Gregor,
    We did a quick check with the J-Link Commander V5.02f and a STM32F756 eval board and programming works as expected.
    The RAMCode is downloaded temporarily into the target's RAM and is used to handle programming.
    Can you please give us a J-Link log file of a session in which this behavior pops up ( Please in a zip container)? The J-Link log file can be enabled in the J-Link Control Panel -> Settings tab (green J-Link icon in the windows task bar during a connection to the J-Link is open).
    Roman
  • Log file attached.
    Note on hardware, I am using a STM32F746 discovery board modified to connect jlink to the CPU's JTAG interface bypassing the on-board STLINK. I had successfully loaded and executed the binary used in the attached log prior to upgrading from 5.02b.
    I get almost the same output as your image above when i run jlink from a command console:
    $ jlink -device STM32F746NG
    SEGGER J-Link Commander V5.02f ('?' for help)
    Compiled Oct 2 2015 20:52:00
    Info: Device "STM32F746NG" selected.
    DLL version V5.02f, compiled Oct 2 2015 20:51:34
    Hardware: V9.20
    S/N: 59200607
    Feature(s): GDB
    Emulator has Trace capability
    VTarget = 3.285V
    Info: TotalIRLen = 9, IRPrint = 0x0011
    Info: Found Cortex-M7 r0p1, Little endian. <==== difference, core is r0p1
    Info: FPUnit: 8 code (BP) slots and 0 literal slots
    Info: CoreSight components:
    Info: ROMTbl 0 @ E00FD000
    Info: ROMTbl 0 [0]: 00001000, CID: B105100D, PID: 000BB4C8 ROM Table
    Info: ROMTbl 1 @ E00FE000
    Info: ROMTbl 1 [0]: 00001000, CID: B105100D, PID: 000BB4C7 ROM Table
    Info: ROMTbl 2 @ E00FF000
    Info: ROMTbl 2 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
    Info: ROMTbl 2 [1]: FFF02000, CID: B105E00D, PID: 000BB002 DWT
    Info: ROMTbl 2 [2]: FFF03000, CID: B105E00D, PID: 000BB00E FPB
    Info: ROMTbl 2 [3]: FFF01000, CID: B105E00D, PID: 000BB001 ITM
    Info: ROMTbl 1 [1]: FFF43000, CID: B105900D, PID: 000BB975 ETM-M7
    Info: ROMTbl 0 [1]: FFF43000, CID: B105900D, PID: 000BB9A9 TPIU-M7
    Cache: Separate I- and D-cache.
    Info: I-Cache L1: 4 KB, 64 Sets, 32 Bytes/Line, 2-Way
    Info: D-Cache L1: 4 KB, 32 Sets, 32 Bytes/Line, 4-Way
    Found 2 JTAG devices, Total IRLen = 9:
    #0 Id: 0x5BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
    #1 Id: 0x06449041, IRLen: 05, Unknown device
    Cortex-M7 identified.
    Target interface speed: 100 kHz
    Gregor Bruce
    • jlink_1.txt
      (80.9 kB, downloaded 965 times, last: )
    I have the same problem as Bruce, i.e.: I use the same STM32F746G-Disco board modified to connect the J-Link over SWD (I removed the local ST-Link V2) and I get the same message when e.g. I try to erase the controller:
    imac:~ lix$ /Applications/SEGGER/JLink/JLinkExe
    Compiled Oct 2 2015 20:55:08
    DLL version V5.02f, compiled Oct 2 2015 20:55:03
    Hardware: V9.30
    S/N: 59304371
    Feature(s): GDB
    VTarget = 3.282V
    Info: Found SWD-DP with ID 0x5BA02477
    Cache: No cache
    J-Link>device STM32f746ng
    Reconnecting to target...
    Info: I-Cache L1: 0 KB, 1 Sets, 16 Bytes/Line, 1-Way
    J-Link>erase
    Erasing device (STM32F746NG)...
    ****** Error: Failed to prepare for programming.
    ERROR: Erase returned with error code -1.
    If I am using a standalone ST-Link V2 (under Windows) I can erase and program the chip. Any ideas what can it be?
    Lix
  • The issue was that the WWDG-SW option bit was unset, so that the controller had the watchdog enabled when getting out of reset. After about 10 ms the watchdog would reset the controller, therefore no operation was possible. After setting this bit using the ST-LINK, everything went back to normal. Are there any means to manipulate the option bits with the J-Link (e.g. using the command line)?
    Lix
    The post was edited 1 time, last by lix ().
  • Hi Lix,
    Thanks for pointing that out. We plan to have a new Version of the J-Link software available at the end of this week.
    Of course the option bytes can be set with the JLink Commander. Please refer to chapter 3.4.2 of the ST manual for further information
    how to program the option bytes.
    - Roman
