I am attempting to download a new production hex file to one of our communication modules which uses the AT91SAM7SE256 micro. I have j-flash V5.02c and a J-Trace CS V3.10 emulator.
Our product uses an external clk signal input from a VPC3+ Profibus ASIC @ 12MHz. The PLL is setup for a Master clk freq of 25.8MHz.
In setting up the J-flash project, I started with the template project for the AT91SAM7SE512(no template for AT91SAM7SE256). I changed the CPU to AT91SAM7SE256 in the project and modified the Init steps for our product. See below. With these settings I am getting the error "Failed to connect Could not establish a connection to the target". However when I bring up the project settings in J-flash on the Target interface tab, it can "Detect" the target as a #0 ARM76TDMI core ID:0x3F0F0F0F. Any ideas on why I cannot connect?
Init
# Action Value0 Value1 Comment
0 Reset 0 0ms
1 Write32 0xFFFFFD44 0x00008000 Disable WD
2 Write32 0xFFFFFF60 0x00290100 EFC0
3 Write32 0xFFFFFF70 0x00290100 EFC1
4 Write32 0xFFFFFC20 0x00000002 Set PLL
5 Delay 200ms
6 Write32 0xFFFFFC2C 0x002A1905 Set PLL and divider
7 Delay 200ms
8 Write32 0xFFFFFC30 0x00000008 Select PLL
9 Delay 200ms
10 Write32 0xFFFFFC30 0x0000000B Set Master Prescaler
Init
0 Reset 0 0ms
5 Delay 200ms
7 Delay 200ms
9 Delay 200ms
