[ABANDONED] EFM32LG debug problem
  • [ABANDONED] EFM32LG debug problem
    I have developed application for Energy Micro microcontroller (EFM32LG940F256).
    I am using j-link base and Emacs witch GCC.
    I connect GDB server with j-link and download code without any problem.
    After some time I can see in Emcas message:
    "Program received signal SIGTRAP, Trace/breakpoint trap
    0x00000000 in _isr_vector"
    On command line I can see output:
    "ERROR: Communication timed out: Requested 4 bytes, received 0 bytes !
    ERROR: Can not read register 15 (R15) while CPU is running
    ...Target halted (PC = 0x00000000)
    Reading all registers
    ERROR: Can not read register 0 (R0) while CPU is running
    ERROR: Can not read register 1 (R1) while CPU is running
    ERROR: Can not read register 2 (R2) while CPU is running
    ERROR: Can not read register 3 (R3) while CPU is running
    ERROR: Can not read register 4 (R4) while CPU is running
    ERROR: Can not read register 5 (R5) while CPU is running
    ERROR: Can not read register 6 (R6) while CPU is running
    ERROR: Can not read register 7 (R7) while CPU is running
    ERROR: Can not read register 8 (R8) while CPU is running
    ERROR: Can not read register 9 (R9) while CPU is running
    ERROR: Can not read register 10 (R10) while CPU is running
    ERROR: Can not read register 11 (R11) while CPU is running
    ERROR: Can not read register 12 (R12) while CPU is running
    ERROR: Can not read register 13 (R13) while CPU is running
    ERROR: Can not read register 14 (R14) while CPU is running
    ERROR: Can not read register 16 (XPSR) while CPU is running
    ERROR: Can not read register 17 (MSP) while CPU is running
    ERROR: Can not read register 18 (PSP) while CPU is running
    ERROR: Can not read register 24 (PRIMASK) while CPU is running
    ERROR: Can not read register 25 (BASEPRI) while CPU is running
    ERROR: Can not read register 26 (FAULTMASK) while CPU is running
    ERROR: Can not read register 27 (CONTROL) while CPU is running
    Read 4 bytes @ address 0x00000000 (Data = 0x20008000)"
    I am using UART as output to write me messages, and from this I know that microcontroller continue to work without any problem.
    I saw similar issue in this thread: STM32F427II debug issues
    But comparing to this issue, my application is not using or programming pins for debug (PF0, PF1 and PF2)!
    Can something else cause this problem ?(
  • Hi Vus,
    Could you provide us with a complete J-Link log file of the debug session?
