I am trying to use a Flasher Portable with a M25P SPI memory. When I use J-Flash SPI I only get 0xFF from the device during identification.
I figured out that the CS line is not going low (even with no hardware attached at all). To test the hardware I tried the regular J-Flash and when trying to connect to a target the same pin is pulled low (so the hardware is okay).
Is that a programmer firmware problem? I use the latest September 18th firmware and 5.02d software.
The post was edited 1 time, last by artur ().
