I'm working on a production/test bench for our company. We need to program two ICs on one PCB. We want to use relays to switch the target for the SWD interface. Also we need to use the #select command (using the RS-232 interface). So I'm preparing the two pairs of *.cfg and *.dat files, booting the Flasher into MSD mode and upload those. Also I write the FLASHER.INI file, just like in the manual.
The problem is that, when I use the #select command, the flasher responds with ACK, but when I invoke #auto, the flasher responds with an error255: public:0:\FLASHER2.CFG, where FLASHER2 is what I've selected. Next, when I check the *.ini file in the MSD mode again, it seems to be updated to the path "public:0:\FLASHER2.CFG" and so on. What is going on?
Please help
Please help
