I'm trying to install the emWIn library as provided by ST as part of CubeF4. ST offers an application sheet which says I need to create two configuration files, but there is so little info I am not sure what these should include. Also I see there are template files in the config library - what are these for? Can you provide info which is a bit more clear? I want to add LCD with menu system and use the touch controller at a later stage of the project. Thanks!
STemWin on the STM32F429I Discovery board
Share
