Unable to program Kinetis K22 devices over JTAG chain
  • Unable to program Kinetis K22 devices over JTAG chain
    I am unable to program a Kinetis K22 device over a JTAG chain with the J-Link Basic tool. Do the J-Link MK22FN1M0xxx12 routines support JTAG chains ?
    I have three ARM devices on a JTAG chain and JLinkCommander correctly identifies these devices:
    1. Found 3 JTAG devices, Total IRLen = 12:
    2. #0 Id: 0x4BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
    3. #1 Id: 0x4BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
    4. #2 Id: 0x079264F3, IRLen: 04, IRPrint: 0x1, ARM926EJ-S Core
    The JTAG chain works for debugging. JLinkCommander allows me select each CPU individually on the chain using the "config" command and I can successfully debug/control each CPU.
    1. J-Link>config 4 1
    2. Info: TotalIRLen = 12, IRPrint = 0x0111
    3. Info: Found Cortex-M4 r0p1, Little endian.
    4. Info: FPUnit: 6 code (BP) slots and 2 literal slots
    5. Info: CoreSight components:
    6. Info: ROMTbl 0 @ E00FF000
    7. Info: ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
    8. Info: ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT
    9. Info: ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB
    10. Info: ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM
    11. Info: ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU
    12. Info: ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM
    13. Info: ROMTbl 0 [6]: FFF43000, CID: B105900D, PID: 003BB907 ETB
    14. Info: ROMTbl 0 [7]: FFF44000, CID: B105900D, PID: 001BB908 CSTF
    15. Found 3 JTAG devices, Total IRLen = 12:
    16. #0 Id: 0x4BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
    17. #1 Id: 0x4BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
    18. #2 Id: 0x079264F3, IRLen: 04, IRPrint: 0x1, ARM926EJ-S Core
    19. Cortex-M4 identified.
    20. J-Link>h
    21. PC = 000063B0, CycleCnt = FCAC4ED9
    22. R0 = 00004348, R1 = A5A5A5A5, R2 = A5A5A5A5, R3 = A5A5A5A5
    23. R4 = A5A5A5A5, R5 = A5A5A5A5, R6 = A5A5A5A5, R7 = A5A5A5A5
    24. R8 = A5A5A5A5, R9 = A5A5A5A5, R10= A5A5A5A5, R11= A5A5A5A5
    25. R12= A5A5A5A5
    26. SP(R13)= 1FFF41E8, MSP= 2000FF98, PSP= 1FFF41E8, R14(LR) = 000063AB
    27. XPSR = 81000000: APSR = Nzcvq, EPSR = 01000000, IPSR = 000 (NoException)
    28. CFBP = 02000000, CONTROL = 02, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00
    29. FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000
    30. FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000
    31. FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000
    32. FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000
    33. FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
    34. FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
    35. FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
    36. FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000
    37. FPSCR= 02000000
    When I use the "device MK22FN1M0xxx12" command, I am unable to erase or program the K22 devices on the JTAG chain.
    1. J-Link> device MK22FN1M0xxx12
    2. Info: Device "MK22FN1M0XXX12" selected.
    3. Reconnecting to target...
    4. Info: TotalIRLen = 12, IRPrint = 0x0111
    5. Info: TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFF11
    6. Info: TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFF11
    7. Info: TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFF11
    8. Info: TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFF11
    9. Info: TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFF11
    10. Info: TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFF11
    11. Info: TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFF11
    When I physically break the chain and connect the J-Link to only a single K22 I am able to program it correctly.
    Can you fix this issue or provide a work around ?
  • No response from Segger Support ?
    Can Segger Suppport please have look into this for me ? I need to know if I have to redesign the board or find another JTAG programmer. This issue has been open for 3 weeks without a response from Segger support. I have also emailed Segger and Segger US for support on this issue but have had no reply.
  • Hello Bill,
    Sorry to hear that your are running into problems.
    This should not happen. Sorry for this.
    Can you please let me know the subject of the e-mail, so I can dig where it got lost?
    I suspect the problem is related to the i.mx28 (ARM926EJ-S Core) on the JTAG chain.
    Would it be possible to get a hardware sample from you in order to reproduce the problem?
    Right now, I do not see any reason why it should not work having also an i.MX28 in the chain.
    Unfortunately, we do not have such a setup here in house.
