Best refresh strategy with external display controller
  • Best refresh strategy with external display controller
    I'm using a TFT display with integrated ILI9341 controller. The connection between MCU and TFT is 16-bits parallel.
    I'm confused about the best strategy to refresh the display when some parts change.
    Suppose I have a black background with one image at the center. Every 1 second, a variable is checked and depending on its value the image at the center changes accordingly. The variable is updated in another task.
    I can use the background window and call GUI_DrawBitmap() in WM_PAINT message. Every 1 second, I call WM_Invalidate() to force the refresh (maybe in a WM_TIMER message).
    This works, but I suspect the GUI library is forced to redraw (i.e., re-write) every pixel of the display, not only the pixels of the image that could change. If the display is big and the image small, this approach wastes a lot of time.
    So what is a better approach? I'm thinking to create an IMAGE widget in WM_CREATE and change the image with IMAGE_SetBitmap() directly in WM_TIMER (raised every second) and not in WM_PAINT.
    I can't use a data cache, because I don't have so much memory space.
  • "I would recommend you to invalidate just the rectangle which might change according to the variable. Also I would recommend to invalidate the rectangle only if the variable changed."
    Suppose I have an image in the rect (0,0)-(10,10). The image depends on the value of variable names status.
    1. enum {IMAGE_A, IMAGE_B} status, old_status;
    2. ...
    3. GUI_RECT r;r.x0 = 0; rx.y0 = 0; r.x1 = 10; r.y1 = 10;
    4. if (old_status != status) {
    5. WM_InvalidateRect(hWin, &r);
    6. old_status = status;
    7. }
    Now, in the WM_PAINT event, what should I write? Should I have to redraw the entire window or only the image in the rect (0,0)-(10,10)?
    In the first case, will the GUI library avoid the real redraw of the full window and changes only the invalid rectangle?
    In the second case, how could I understand in WM_PAINT event which part of the window to redraw?
    The post was edited 1 time, last by giusloq ().
    Yes, exactly. You do not have to change anything in the paint event.
    Adrian
