Fatal error: Can not read register 9 (R15 (PC)), CPU may not be halted
  • Fatal error: Can not read register 9 (R15 (PC)), CPU may not be halted
    I have downloaded and installed the latest J-Link software (V3.94) but for some reason it is not possible to debug because of the following error:
    Fri Oct 31 13:46:33 2008: Fatal error: Can not read register 9 (R15 (PC)), CPU may not be halted
    I am working with the IAR Embedded workbench IDE 5.0 in combination with the microcontroller LPC2468 from NXP
    Prior to this error a image is loaded into flash through J-Link. The image has been loaded correctly into flash because if I power cycle the target everything works OK.
    Can anyone help with this error ??
    Thanks Piet
    Hereunder is the complete debug log
    Fri Oct 31 14:07:47 2008: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 5.0\ARM\config\flashloader\NXP\FlashNXPLPC512k2.mac
    Fri Oct 31 14:07:49 2008: DLL version: V3.94
    Fri Oct 31 14:07:49 2008: Firmware: J-Link ARM V6 compiled Oct 15 2008 10:48:36
    Fri Oct 31 14:07:49 2008: JTAG speed is initially set to: 32 kHz
    Fri Oct 31 14:07:49 2008: TotalIRLen = 4, IRPrint = 0x01
    Fri Oct 31 14:07:50 2008: RESET has cleared breakpoint, using default reset strategy.
    Fri Oct 31 14:07:50 2008: Resetting target using RESET pin
    Fri Oct 31 14:07:50 2008: Hardware reset with strategy 1 was performed
    Fri Oct 31 14:07:50 2008: Initial reset was performed
    Fri Oct 31 14:07:50 2008: J-Link found 1 JTAG device. ARM core Id: 4F1F0F0F
    Fri Oct 31 14:07:50 2008: Device at TAP0 selected
    Fri Oct 31 14:07:50 2008: JLINK command: map ram 0x40000000-0x40003fff; map indirectread - FAILED
    Fri Oct 31 14:07:51 2008: RTCK reaction time is approx. 315ns
    Fri Oct 31 14:07:51 2008: Auto JTAG speed: Adaptive
    Fri Oct 31 14:07:52 2008: 9604 bytes downloaded and verified (8.83 Kbytes/sec)
    Fri Oct 31 14:07:52 2008: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 5.0\ARM\config\flashloader\NXP\FlashNXPLPC512k2.out
    Fri Oct 31 14:07:52 2008: Target reset
    Fri Oct 31 14:08:46 2008: Program exit reached.
    Fri Oct 31 14:08:47 2008: TotalIRLen = 4, IRPrint = 0x01
    Fri Oct 31 14:08:47 2008: RESET has cleared breakpoint, using default reset strategy.
    Fri Oct 31 14:08:47 2008: Hardware reset with strategy 1 was performed
    Fri Oct 31 14:09:04 2008: Fatal error: Can not read register 9 (R15 (PC)), CPU may not be halted
  • Piet,
    it seems the problem is that the reset after download of the flash loader does not work right.
    Can you send the content of the flash memory or (even better) the IAR project which has
    caused this to support@segger.com ?
    Also: Which board are you using ?
    We would like to investigate what is going on.
    BTW: As a work-around, you should be able to use NXPs flash magic tool. Since it puts the CPU in
    a bootloader mode, it should be possible to erase the flash and continue to work with IAR EWARM.
    Rolf
  • Rolf,
    We modified the delay from 0 ms to 50 ms of the reset "Hardware, halt after delay (ms)" in "Options - Debugger - J-Link/J-Trace" in the setup tab and now everything works OK. Probably this delay now gives enough time for the low-level setup of our application.
    Piet
