LPWFI - Relocating Interrupt Vector - STR711
  • LPWFI - Relocating Interrupt Vector - STR711
    Dear All.
    I'm using an STR711 with embOS version: 3.52c and Keils uVision3.
    I started developinng on the Examples shipped with the OS
    My application is currently running from ROM.
    I have to enter in the LPWFI mode switching OFF the Master Voltage Regulator and the FLASH. I did it and the power consumption drops correctly, unfortunatly the application block after a while. The crash is causes by the switching off of the FLASH which need at least 20us after the interrupt to return functional. I found that I should relocate my interrupt vector to RAM in order to avoid an istantaneus access to the ROM. How can I do that?
    thank you in advance for your help and attention
    Luca
