EDIT limits for float data entry
  • EDIT limits for float data entry
    When using EDIT_SetFloatMode(), you are required to set minimum and maximum values. If these are set to FLT_MAX * -1 and FLT_MAX respectfully, then the number is not displayed, and often a few random characters are seen. What is the maximum length of floating point numbers that can be displayed? Unfortunately I can not find any indication in the manual.
    Craig
