Hello
I am working with Keil MDK, and I would like to use Access breakpoints (or Watchpoints). Since Keil seems not to support this feature, both in the RDI driver and in the direct driver, is there a way (or there will be a way) to make this work? A simple workaround could be to add a little dialog window to the JLink status window, in order to directly set watchpoints.
Thank you
Thank you
