Programming option bytes on STM32F051 with J-Link
  • Programming option bytes on STM32F051 with J-Link
    I am trying to program the option bytes (read protection) on a STM32F051 with the j-Link Commander.
    I read UM8001 and UM08003, in both manuals only J-Flash is mentioned (J-Link only for unsecure).
    Can i set the read protection with j-Link Commander? Does anybody has a example?
    Here my code where i want to add the read protection
    1. device STM32F051K8
    2. r
    3. h
    4. loadbin MyProgram.bin, 0x0
    5. verifybin MyProgram.bin, 0x0
    6. // Enable read protection
    7. g
    8. qc
    Thank you :)
    The option bytes of the STM32F051 can be set by performing several read/write accesses to different flash registers.
    Please find below a small generic sample sequence which can be adapted into J-Link Commander syntax (e.g. w4 to write to a register).
    #define FLASH_OPTOBL (1 << 13) // Start Option Byte Loader and force system reset
    #define FLASH_OPTWRE (1 << 9)
    #define FLASH_OPTPG (1 << 4)
    #define FLASH_OPTER (1 << 5)
    #define FLASH_KEY1 (0x45670123)
    #define FLASH_KEY2 (0xCDEF89AB)
    #define FLASH_BSY (0x00000001)
    // Unlock flash block
    FlashKEYR = FLASH_KEY1;
    FlashKEYR = FLASH_KEY2;
    FlashCR = 0;
    // Erase option bytes
    FlashOPTKEYR = FLASH_KEY1;
    FlashOPTKEYR = FLASH_KEY2;
    FlashCR = FlashCR | FLASH_OPTWRE | FLASH_OPTER; // Enable "Option byte erase"
    FlashCR = FlashCR | FLASH_OPTWRE | FLASH_OPTER | FLASH_STRT; // Start operation
    while (FlashSR & FLASH_BSY);
    // Program option bytes
    FlashCR = FlashCR | FLASH_OPTWRE | FLASH_OPTER; // Enable "Option byte program"
    0x1FFFF800 = 0x55AA; // Values to set device to "unlocked state"; Must adapted according by the user
    // Trigger the Option Byte Loader to activate the programmed option bytes
    FlashCR = FLASH_OPTWRE | FLASH_OPTPG | FLASH_OPTOBL;
    Below a small sample how the code must be adapted into J-Link Commander syntax for the first 3 lines:
    w4 0x40022004 0x45670123
    w4 0x40022004 0xCDEF89AB
    w4 0x40022010 0
    Erik
  • Hello Erik,
    thanks for your detailed help.
    I read the procedure to set the option bytes in the STM32F0xx RM but i did not know hat to set them by the j-link commander.
    You wrote i had to set the option bytes with the j-link commander syntax. Is it possible to write it into jlinkSkript (with C-like syntax) and to
    start it by the j-link commander? If i type "?" i see all commands but there are no commands like "if" or "while".
    Can I add some text to the stdout by the commander? After programming and setting up the read protection i would like to post some
    text at the console like "Program, verification and locking successfully)".
    Best Regards
    HawkEye
    You could pass a command file to the J-Link Commander via command line option.
    J-Link Commander will perform the commands located in the file in batch mode. So you could automate this process.
    For further information, please refer to chapter "3.2.1 Command line options" of the J-Link user manual: UM08001.
    As the command file does not allow do - while loops, you have to enter defined sleeps instead of reading the status register and waiting
    for a ready bit is set. This can be done by passing the "sleep" command. A list of all commands can be outputted by writing "?" in the J-Link Commander.
    You should be able to adapt the sequence by using the commands below:
    w4 <Addr> <Value>
    mem32 <Addr> <Value>
    sleep <TimInMS>
    If you need any further help, please do not hesitate to ask.
    Custom user output is currently not supported by J-Link Commander command files. We will discuss internally if we will add such a opportunity to the tool.
    Erik
