errors when flash programming kinetis mk20dx256xxx7
  • errors when flash programming kinetis mk20dx256xxx7
    I have a j-link base which I would like to use to flash program the mk20dx256xxx7 via jlink.exe
    I am running the following script:
    device mk20dx256xxx7
    unlock kinetis
    erase
    loadbin test.bin, 0x3e000
    loadbin host_app.bin, 0x4000
    loadbin lcs_bootloader.bin, 0
    It works fine and programs the device if the device has not been preprogrammed previously. Programming the lcs_bootloader.bin results in the flash configuration field bytes be set to protect 2KB of flash starting at 0x3e000 (ie. it protects the test.bin that was programmed).
    I power down the device and disconnect jlink, then connect the jlink and power up the device and then re execute the script. I get the error that could not erase sector 124 @ address 0x3e000. I'm not sure why this would be the case as I thought that the unlock and erase command would do a mass erase and would ignore any protected segments. Any help would be greatly appreciated. The following is the output of the jlink.exe when script is run:
    C:\Program Files (x86)\SEGGER\JLink_V490e>jlink prog_lcs.jlk
    SEGGER J-Link Commander V4.90e ('?' for help)
    Compiled Sep 8 2014 18:46:42
    Script file read successfully.
    DLL version V4.90e, compiled Sep 8 2014 18:46:31
    Firmware: J-Link V9 compiled Sep 5 2014 18:54:08
    Hardware: V9.00
    S/N: 59300400
    Feature(s): GDB
    VTarget = 3.277V
    Info: Found Cortex-M4 r0p1, Little endian.
    Info: FPUnit: 6 code (BP) slots and 2 literal slots
    Info: TPIU fitted.
    #0 Id: 0x4BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
    Cortex-M4 identified.
    Target interface speed: 100 kHz
    Processing script file...
    Info: Device "MK20DX256XXX7" selected (288 KB flash, 64 KB RAM).
    Reconnecting to target...
    Info: TPIU fitted.
    Info: ETM fitted.
    Info: ETB present.
    Info: CSTF present.
    Found SWD-DP with ID 0x2BA01477
    Unlocking device...O.K.
    Info: Found SWD-DP with ID 0x2BA01477
    Info: TPIU fitted.
    Info: ETM fitted.
    Info: ETB present.
    Info: CSTF present.
    Erasing device (MK20DX256xxx7)...
    ****** Error: Failed to erase sectors 124 @ address 0x0003E000 (Algo135: Flash p
    rotection violation. Flash is write-protected.)
    Info: J-Link: Flash download: Total time needed: 1.239s (Prepare: 0.311s, Compar
    e: 0.000s, Erase: 0.899s, Program: 0.000s, Verify: 0.000s, Restore: 0.028s)
    ERROR: Erase returned with error code -5.
    Downloading file [test.bin]...
    ****** Error: Programming failed @ address 0x0003E000 (Algo135: Flash protection
    Info: J-Link: Flash download: Total time needed: 1.692s (Prepare: 0.690s, Compar
    e: 0.351s, Erase: 0.000s, Program: 0.263s, Verify: 0.000s, Restore: 0.386s)
    Error while programming flash: Programming failed.
    Downloading file [host_app.bin]...
    Info: J-Link: Flash download: Total time needed: 9.888s (Prepare: 0.690s, Compar
    e: 0.284s, Erase: 0.000s, Program: 8.521s, Verify: 0.000s, Restore: 0.391s)
    Downloading file [lcs_bootloader.bin]...Info: J-Link: Flash download: Flash prog
    ramming performed for 1 range (6144 bytes)
    Info: J-Link: Flash download: Total time needed: 1.132s (Prepare: 0.475s, Compar
    e: 0.006s, Erase: 0.000s, Program: 0.445s, Verify: 0.002s, Restore: 0.202s)
    O.K.
    Script processing completed.
    J-Link>mem8 0x400,100
    00000400 = FF FF FF FF FF FF FF FF FF FF FF 7F FE FF FF FF
    00000410 = 00 02 00 00 72 B6 00 F0 43 FA 00 F0 37 FB 01 21
    00000420 = 4B 20 00 F0 DF FB DF F8 D4 03 4F F4 80 71 01 60
    00000430 = 00 21 4B 20 00 F0 F3 FB 00 F0 2C FD 00 F0 1D F8
    The post was edited 1 time, last by charles ().
